Vizio P50HDTV10A power up display issue
  • pss3757
    • Dec 2012
    • usa
    I have had this tv for over 6 years and had from day one.
    I have beginning to have an issue that may be simple.
    When i first turn it on, after not watching it in a while, it powers right up, sound and video....but i have these 3 or 4 vertical snow bands, each 8-10 inches wide. You can still see the picture and have good sound, and it kind of tries to clear up. I usually turn the tv off, wait a couple seconds, turn it back on and all is fine !!
    It only seems to happen when i have not used the set in a couple days. Almost like it warms up and clears up. Either way, it is consist in doing this every time i turn it on, after not using it for a day or two.
    ANyone know what these symptoms are indicative of??
    Power supply, z board, y board, main board ??? I am good at replacing things....not so good at diagnosing the problems though.
    thanks in advance for any and all assistance.
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • justice171
    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
    by justice171
    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
    1. Verified that all critical voltages are present:
      • 3.3V and 5V are always present if DC is plugged.
      • 1.8V on the BIOS chip is present.
    2. Checked the power button functionality:
      • When pressed, the voltage drops to 0V, indicating the button is functional.
    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
      • Confirmed connectivity is intact, ruling out issues
    11-26-2024, 12:39 AM
  • claws77
    lenovo flex 5 14itl05 power sequence issue
    by claws77
    hi guys, my motherboard will not start no matter what
    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
    but rest nothing happens no sign of life.
    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
    i have no knowledge of motherboards ....
    10-20-2024, 02:48 PM
  • yaya3gmax
    Laptop Power Issue – Works on Battery, Fails on Adapter Load
    by yaya3gmax
    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
    Symptoms:
    • Laptop works normally on a pre-charged battery.
    • Battery does not charge when adapter is connected.
    • Without battery:
      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
      • Speakers “pop” when power cut occurs indicating harsh sutdown.
      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
    08-21-2025, 07:16 AM
