Samsung LE26B450C4W Dead
  • nic2
    • Dec 2012
    • 6
    • abruzzo
    Hello I have read several posts on the subject but I have not found a case similar to mine. The TV is dead no picture no sound no red light in.standby. Checked voltage CP 815 = 326 v.dc. on the power circuit BN44-00259A. The connector CNM802 provide no evidence output voltage. The capacitors seem undamaged no anomalies. I replaced two electrolytic capacitors (CP809 and CM808) leveling power of the integrated FAN 7530 and who had a ICE3BR0665J ESR too high unsuccessfully checked all the diodes and transistors involved but do not come out
    Who can help me?
    thanks
    Service Manual:
    http://elektrotanya.com/samsung_ln26.../download.html
    diagram at
    https://www.badcaps.net/forum/attach...5&d=1300162507
  • nic2
    • Dec 2012
    • 6
    • abruzzo
    Re: Samsung LE26B450C4W Dead
    Anyone help me?
      So you are not getting any voltages from any pin of the connector CNM802?
      How about if you disconnect that connector, what do you get?
      Fuse FM802S is OK?
      • nic2
        • Dec 2012
        • 6
        • abruzzo
        Thanks for the reply and I apologize for my English I translate with the help of google translated. I unplugged the power board BN44-00259th, the power is turned on and I find about 326 cp 815 volt fuse on that FM802s. (I find the same voltage 326 volt tester positioned DCV). Fuse is OK. The connector CNM802 I do not detect any tension. The mass was taken from pin 10 which is the mass of the CP 815 but I do not detect anything. I noticed that the diode zm801 measured by the tester was short on the card so I disassembled and measured again with the test results in reversing the leads short. Could this be the problem? I do not have this diode IN4740AS tomorrow I'm going to buy it ... Damage that could result?
        I checked the capacitors and are not damaged and there are burns
        I can do other controls?
        thanks for your help
        • nic2
          • Dec 2012
          • 6
          • abruzzo
          I replaced the diode IN4740AS - zm801 found in short and magically the TV is on and everything is back to work properly. I could not find the diode and I used a zener diode compatible. The problem has been resolved. Thank you.
          • Mgt280y
            • Jul 2016
            • 5
            • England
            Good evening hopefully someone can help I have the above meantioned tv and it died I have opened up and it looks like it's a cap as it lookes like it has exploded and covered the neighbouring heat sink with soot can anyone provide the aspects for the offending cap as I can't read the text it is marked up on the board as "CP810" just need the values so I can replace fingers crossed
              Did you look at the schematic?
              0.22nF (220pF) 1KV, it is snubber cap (ceramic type), I would go with higher Voltage rating.
              • Mgt280y
                • Jul 2016
                • 5
                • England
                Not sure what the type is called as I haven't used one its a small blue one looks like a ceramic couldn't find a schematic for it
                  My post 3 has the schematic.
                  • Mgt280y
                    • Jul 2016
                    • 5
                    • England
                    Oh yeah missed them I found a 220pf 2kv would that be better
                      That will be fine.
                      • Mgt280y
                        • Jul 2016
                        • 5
                        • England
                        Cool thank you
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Let us know if that solved the problem! Im curious
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
