Daewoo LCD 42" model DLP-42C1
  • bohaboha
    • Nov 2012
    • 1048
    • sweden
    #41
    Re: Daewoo LCD 42" model DLP-42C1
    Here i am again.
    When plugged there is only the red LED switching to green non stop on the front panel
    the screen is black and nothing happend att all no clicking or anything else.
    nothing happend too when pushing on the different button on the side.
    now some mesure on the psu board and the main board
    the Psu board :
    CN3 :
    12V =0.00VDC
    12V =0.00
    GND =0.00
    GND =0.00
    5VS =5.11VDC
    P/O =0.00VDC
    GND =0.00VDC
    CN5 :
    O/B =0.00VDC
    DIM =0.00VDC
    GND =0.00VDC
    GND =0.00VDC
    GND =0.00VDC
    GND =0.00VDC
    24V =0.00VDC
    24V =0.00VDC
    24V =0.00VDC
    24V =0.00VDC
    CN6 :
    O/B =0.00VDC
    DIM =0.00VDC
    GND =0.00VDC
    GND =0.00VDC
    GND =0.00VDC
    GND =0.00VDC
    24V =0.00VDC
    24V =0.00VDC
    24V =0.00VDC
    24V =0.00VDC
    CN4 :
    DIM =0.00DCV
    B/O =0.00DCV
    NC =3.29DCV
    GND =0.00DCV
    GND =0.00DCV
    NC =0.01DCV
    12V =0.01DCV
    12V =0.01DCV
    CN2 :
    30V =0.30DCV
    30V =0.30DCV
    GND =0.00DCV
    GND =0.00DCV
    on some capacitor :
    C25 =3.87VDC
    C32 =5.11VDC
    C31 =5.11VDC
    it is not possible to reach the bakside of the big capacitor when it is on the tv but i did a
    test on the table and it was 328VDC.
    The power button or any other not working so just plugg in to start
    now some test on the main board
    IC507
    1 =0.00DCV
    2 =0.00DCV
    3 =0.40DCV
    IC 508 :
    1 =0.00DCV
    2 =0.03DCV
    3 =0.40DCV
    IC711
    1 =5.09DCV
    2 =3.29DCV
    3 =0.00DCV
    P803A this one is connected to CN2 on the psu and there is no labelle
    1 =0.00DCV
    2 =0.00DCV
    3 =0.30DCV
    4 =0.30DCV
    P804A
    A/dim =0.00dCV
    BLK_ON=0.00DCV
    LVDS_SW=3.29VDC
    GND =0.00DCV
    GND =0.00DCV
    5V_LVDS =0.01DCV
    5V_LVDS =0.01DCV
    NC = 0.01VDC
    hope this help thank you
      OK, P/O is continuously low. Beg borrow or steal a 100~470 ohm, unplug PSU connector from main board side, and wire the resistor from 5VS to P/O, rails should come up, PFC cap should rise to 390V or so.
      • bohaboha
        • Nov 2012
        • 1048
        • sweden
        #43
        Ok, with 100ohm,the PFC cap C23 have 322dcv i took the mesure on the +and - pole of
        the capacitor. it is the same result with the jump i did se early post
        something have to be wrong in the Q1,Q5 and IC1 area but i do not know
          Do the main outputs rise at all?
          • bohaboha
            • Nov 2012
            • 1048
            • sweden
            #45
            but you tell me to unplugg the PSU from the main?
              Yes, but you should still be able to test the outputs...
              • bohaboha
                • Nov 2012
                • 1048
                • sweden
                #47
                ok now when i plugg in i get a very diffuse mixed colored screen for 2 or 3 seconds then
                bak to black.
                the mesure on the main :
                IC 507
                1 =0.00DCV
                2 =2.49DCV
                3 =5.22DCV
                IC 508
                1 =0.00DCV
                2 =3.26DCV
                3 =5.21DCV
                IC 711
                1 =5.09DCV
                2 =3.29DCV
                3 =0.00DCV
                  That may be expected to see that from main board if it not expecting power.
                  Does 24V come up?
                  • bohaboha
                    • Nov 2012
                    • 1048
                    • sweden
                    #49
                    yes now the 24V and even the 30V on the PSU are ok
                    • bohaboha
                      • Nov 2012
                      • 1048
                      • sweden
                      #50
                      so it allways a problem on PSU but can you point a specific area ?
                        If you have good PSU voltages it's unlikely to be the PSU. The red/green blinking to me makes me think of mian board issue -- could be firmware problem or some other issue.
                        • bohaboha
                          • Nov 2012
                          • 1048
                          • sweden
                          #52
                          but the actuel voltage on the PSU is due to 100 ohm resistor cross 5vs and P/O if it is off
                          then the voltage will fall down again or shall i leave the resistor there so long?
                            Yeah, but if the main board is faulty it won't send the P/O signal. The 100 ohm resistor proves the PSU is working, at least partially (still unsure about PFC, but I think it should still work.)
                            • bohaboha
                              • Nov 2012
                              • 1048
                              • sweden
                              #54
                              thank you, next i will do some more test in the Q1,Q5 and IC1 area to be shure that the
                              component there are ok now it is time to go to bed thank you again
                                HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                09-06-2024, 05:27 AM
                                HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              • edugimeno
                                Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                by edugimeno
                                Hi!!
                                Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                At a certain point, moving stuff around, I put all wires back in place and...
                                03-24-2024, 02:31 PM
