Samsung HP-T4254 Problem
  • crdz66
    • Nov 2012
    • 242
    Hi Everyone.
    Need you opinion with my Samsung Plasma 42" problem.
    I have a very white mark on the Left Side of my tv (X-Board Sustain Board Side) and once I get Video there are a lot red dots running on top,bottom and Right Side on my and the white mark still remain)
    The Second Pic is when I turn off the tv.
    Check voltages power supply-sustain boards good
    Check voltages power supply-main board (Missing 12v, rest is fine)
    Check voltages power supply-bottom buffers or drivers fine.
    Another I did it was disconnect the buffer bottom board from power supply and once turn off the tv, the black shadow spot no show up.
    Any comment can be appreciate.
    Regards
    Re: Samsung HP-T4254 Problem
    When the TV is off, you still see the screen lit up??
    Likely, your problem is with the Vset or Vrst voltage, can you post a picture of the panel sticker (white sticker, "NTSC/PAL SAMSUNG SDI" on plasma panel.)
    • crdz66
      • Nov 2012
      • 242
      Just for 2 Secs. if bottom buffer is connected.
      • crdz66
        • Nov 2012
        • 242
        pics
          OK, that may be normal shut down procedure but there is noise on picture.
          Panel sticker is on inside of TV.
          • crdz66
            • Nov 2012
            • 242
            Sometimes x-board buffer make noise.
            pics attached
              Along the power connector going to the Y-main, do you see pins marked Vs and Va? Check the voltages on them.
              It is normal for the sustain boards to make noise due to the very high currents flowing.
              • crdz66
                • Nov 2012
                • 242
                205 volts going to y-board and x-board.
                  What does Va measure?
                  • crdz66
                    • Nov 2012
                    • 242
                    63.4volts
                      So both those are good we need to find Ve and Vsc. Can you post pictures of your Y-main and X-main. It is best to use daylight and not flash as flash creates glare.
                        09-07-2024, 05:50 AM
                      • howardc64
                        Samsung UN55JU650DF network/streaming problem
                        by howardc64
                        Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                        This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                        07-09-2025, 12:44 PM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
