Panasonic TH-P42V20A SC fault
  • dorz
    • Nov 2012
    • 6
    Hey guys, first post here but ive done a bit of searching, so much information on this forum it is amazing
    my story is pretty similar to the thread below.
    got given the tv, fault was 4 blinks - power. VSUS was basically 0v. unplugged SC2, VSUS jumped up to ~200v, and now giving me 7 blinks. unplugging the SC SOS cable gives me 6 blinks.
    https://www.badcaps.net/forum/showth...4+blink&page=2
    this thread was incredibly helpful, including post 23, which is almost exactly what has happened to my SC board.
    i can see IC521 looks to be damaged, has a burn mark on the top of the IC. the SC2 connector pins are almost a dead short, 0.6ohm or something across them. i have removed IC521, still shorted, so i will need to trace the circuit and remove some fets to test them.
    couple of questions i have are: what is IC521? it is a mitsubishi M81737FP. what would cause this to pop? does anyone have any tips to troubleshooting these boards?
    i cant find the same circuit boards for sale (TNPA5105 for 42"), only the ones for 46" or 50". what are the differences between the boards besides component locations? has anyone tried substituting boards and or components on these SC boards?
    is there anywhere in australia i can get a TNPA5105 board without spending a fortune?
    Thanks!
    Dorz
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-P42V20A SC fault
    Looking at Shopjimmy he has no stock at all. Pretty clear indication to me these fail a lot.
    There's a 42" in Canada Ebay $70 postage $96 but he does state to contact him for postage as i'd be surprised if it actually costs this much.
    There's also a 7 piece semiconductor replacement kit in UK but $65 so I would find a board unless you can be sure everything else is good otherwise you may end up with still a dead board and empty wallet.
    It covers Q421/Q422/Q451/Q401/Q402/Q661/D482
    i think those ic are driver chips which I have 2 on my dead 50" board but i think you will find a lot of shorted Transistors and diodes which are the cause.
    there's also a 46" board which looks closer to the 42 but unless you can find service manuals for the 42 and 46 to compare components and voltage settings it would be a bit of a guess.
    • dorz
      • Nov 2012
      • 6
      Thanks for your advice TW2005
      i will have a look to see whether the boards are interchangable, hopefully they are.
      will contact the ebay seller too, thanks so much for your time finding that for me!
      Dorz
      • freakaftr8
        • Oct 2012
        • 3743
        Look for a shorted Zener diode in the circuit of the blown MOSFET.
        • dorz
          • Nov 2012
          • 6
          had a poke around then, couldnt find any shorted zeners around there. i might pull off a couple of fets later today if i get time hopefully i can find the fault via elimination, i will have to check the ic to make sure it is definitely blown too.
          • ryan74
            • Oct 2012
            • 471
            • usa
            im working on a panasonic TC-P42U1
            many boards were advertised as TNPA4829 so i ordered one
            barcode sticker on my sc board said TNPA4829AD
            the board i recieved was TNPA4829AB
            the connections to SD/SU boards were different so BEWARE you may need exact replacment. I even emailed the seller before shipment to verify the correct part and he still sent the wrong one.
            I think i ordered the correct one now but it cost me $90
            • tw2005
              • Oct 2011
              • 6458
              That's a good tip. something easily missed.
              Do you think you could have desoldered and swapped the connectors from your original?
              Board layout looks the same. Also where TPVAD is, the 7 pin powerchip does yours have a heatsink and the wrong one not?
              • dorz
                • Nov 2012
                • 6
                no mine doesnt have a heatsink... not sure if you're referring to me or ryan though.
                as far as i can see, the only different components between the 42, 46 and 50" boards are the location of a couple of coils (L401,2,3, L411,2,3). connectors look the same,and in the same places. i might bite the bullet and try this one out with a 46" board... the SC boards do only supply the power to the panel doesnt it, not control the pixels?
                • tw2005
                  • Oct 2011
                  • 6458
                  No, It was off topic a bit and to Ryan hence the quote.
                  I think there's more than just the coils. Capacitors and also they may use different transistors in the same locations or even additional ones in vacant spots. Have a closer look at the 50" board and you should see what I mean.
                  I downloaded 42 and 46 service manuals but found out it was updated to the new SN boards which incorporates the buffers and SC all in one so no good for comparison.
                  Was the Canadian board too expensive with freight?
                  • tw2005
                    • Oct 2011
                    • 6458
                    Try downloading this. My connection dropped out so it won't let me download again today. Hopefully it has a SC board.
                    At least you will have schematics,layouts and you could go to the parts listing and compare whats used on each board.
                    Huge task though.
                    If you go for the 46 then you will be a pioneer I feel.
                    i've attached the 46" manual.
                    • dorz
                      • Nov 2012
                      • 6
                      thanks heaps Tw2005, downloading now.
                      ill have a gander
                      i didnt manage to find the canadian board on ebay.ca, have you got a link for it? my searches only pull up the 4 from us/uk from the 'international sellers'
                      cheers!
                      • tw2005
                        • Oct 2011
                        • 6458
                        ill have a gander
                        cheers!
                        Did you tick the check box, include description? Always helps to dig up more in the search.
                        It's Rev AD which I suspect yours is.
                        Says it was purchased from Shopjimmy so good chance it's fairly new pulled from damaged in Transit new TV.
                        Would not hurt to pick the guys brains for his fault as he states he bought it thinking it was SC but eneded up being A-board.
                        But yours does sound like the same fault as mine for SOS4.
                        http://www.ebay.com.au/itm/Panasonic...item2324ebafda
                        Hope you don't miss out on it. You may have to just cop whatever the cost is given the rarity of these parts. Still much cheaper than getting new here or paying someone to fix.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Buy it! It should cost SFA. He's quoting Canada Express international(probably an Ebay built in calculator)
                          Options range from Small Packet-Int'l Surface $17 (4-6 weeks), Small packet-Int'l Air $39 (6-10 business days) and it goes up from there.
                          Me personally would opt for small Air unless you don't mind waiting forever. I'd stipulate to the the seller which option exactly you want. he does say choose your own.
                          http://www.canadapost.ca/cpotools/ap...execution=e1s2
                          Good Luck.
                          • dorz
                            • Nov 2012
                            • 6
                            contacting him now, he is changing it for me to the small packet air
                            thanks so much for your help TW2005. where in australia are you?
                            • tw2005
                              • Oct 2011
                              • 6458
                              Newcastle but not for long , Darwin 2013
                              • ryan74
                                • Oct 2012
                                • 471
                                • usa
                                I could have swapped them but there were other differences
                                Heatsinks all matched
                                Adjustment pot missing
                                1 less capacitor
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  1 less capacitor
                                  Blind as a bat. I did miss all those.
                                  • Rictech
                                    Panasonic SA-MAX770PU SMPSU board fault....
                                    by Rictech
                                    Hello everyone. πŸ˜€
                                    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                    There are no devices that have exploded or otherwise show signs...
                                    08-26-2024, 01:05 AM
                                  • chockimon
                                    Panasonic TX-40AX630B has developed a fault
                                    by chockimon
                                    I bought a Panasonic 40" TX-40AX630B TV from Richer Sounds 7 years ago and it has developed a strange fault. If I attempt to press any button on the back of the TV or remote control (access media features etc.) the TV locks up for a few minutes or longer and sometimes goes blank. However, if I turn the TV off and on again and quickly select a channel it will work fine all day long, as long as I don't touch the remote or controls on the back of the TV.
                                    I've tried changing batteries on the remote, changing plug sockets and doing other things such as a...
                                    06-02-2022, 12:03 PM
                                  • fixxy88
                                    Panasonic 55DX600u second fault - panel brightness pulsing on right side
                                    by fixxy88
                                    After getting the backlights up and running a second fault has emerged on this TV. I was going accept defeat and move on but thought I'd have a quick look at it in case it was something simple. The right side of the display exhibits a panel brightness (not backlight brightness) pulse every 2-3 seconds in a stable timing.
                                    I poked about on the TCON test points and found one voltage that is fluctuating in the same pattern. VGH-ODD (Pin 47 of U10) is sitting at ~-6.5v then goes up to ~28v when the brightness pulses then goes back down to ~-6.5v again in a repeating pattern.
                                    03-22-2023, 02:58 AM
                                  • Andre Gilbert
                                    by Andre Gilbert
                                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                    11-20-2024, 08:52 PM
                                  • howardc64
                                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                    by howardc64
                                    • Prior owner tried a replacement main board. No difference.
                                    • Samsung 2x red blinking standby LED = panel fault
                                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                    07-19-2025, 10:54 PM
