Samsung 52" LE52A557P2FXXC the LED is constantly about 24 times in sec.takt
  • elmedin007
    • Oct 2012
    • 7
    • germany
    Hello
    my Englich is not good, so sorry for that .....
    have a problem with my LCD TV Samsung 52 "in the service menu LE52A557P2FXXC have adjusted slightly so that no image is more!
    I bought a signal board gelichen type mainboard BN41-00974B on ebay and replaced.
    now everything is wonderful but I have a problem:
    when I press Power flashes 5 times and then you will hear is image and the problem starts again from scratch
    So the LED is constantly about 24 times in sec.takt and stops briefly and then it goes back further in time with 24 sec .. takt , Which is a code?
    if so what does that mean and what needs to set man in the service menu?
    ps. a factory reset in the service menu had conducted more willing I will make no more no recommendations!
    I'm going crazy .....
    greeting elmedin007
    Re: Samsung 52" LE52A557P2FXXC the LED is constantly about 24 times in sec.takt
    What setting did you adjust on the original board?
    Was the replacement board an -EXACT- match - for example, for a 52" Samsung of the A557 series, European model?
    • elmedin007
      • Oct 2012
      • 7
      • germany
      well ... it's just the same type of 40 "
      However, when I installed the new board and went in the service menu and saw standing there at 40. "
      then have to 52 "set but without success
      regards
        Problem is there are a lot of differences between panel configurations etc. between 40" and 52" screen sizes. Does the original board not work at all - have you tried changing the setting back?
        • elmedin007
          • Oct 2012
          • 7
          • germany
          yes the old board I still have it but there is no picture more.
          you could delete the Eeeprom IC7004 but it must Eeeprom be removed, but no tool for it
          or you know how to delete the Eeeprom without removing the eeprom needs?
          Or do you have any ides how to live considering the old motherboard?
          regards
            Is the EEPROM on the top or the bottom of the board?
            It can be erased on many Samsung TVs by touching pins 4 and 5 together while the TV is powered on. This will reset TV to defaults.
            • elmedin007
              • Oct 2012
              • 7
              • germany
              yes good ide I know with digital receivers (thank you in advance of them)
              So the eeeprom IC7004 is on the upper side near the connector t-con
              which pins must be connected?
              There are left and right 8 pins!
              • elmedin007
                • Oct 2012
                • 7
                • germany
                pins 4 and 5 have links and the tv did restart but still no picture ...
                no idea how I will continue
                  Try either of these (one should work)
                  Option #1
                  Put TV in standby. On remote control, Info, Menu, Mute, Power. Service menu should appear when TV powers on.
                  Option #2
                  Put TV in standby. On remote control, Mute, 1, 8, 2, Power. Service menu should appear when TV powers on.
                  Do you see any service menu at all?
                  • elmedin007
                    • Oct 2012
                    • 7
                    • germany
                    So in the old motherboard with option # 1 and # 2 have started trying more but the screen remains dark, no sevice menu
                      OK, I would say that motherboard is difficult to get working for now.
                      I suspect that the 40" board simply isn't programmed properly to work with the 52" chassis. It may even be faulty - I cannot be certain. But, I am still a little confused by your explanation of the symptoms. Is it possible to show a video of the problem?
                      BTW, I took GCSE German for two years (compulsory), but can hardly remember any of it... Your English is far better than my German.
                      • elmedin007
                        • Oct 2012
                        • 7
                        • germany
                        Ok, I have to still go to work at night, I'll try tomorrow after work to upload a video up.
                        Incidentally, thank you for the compliment ... honestly I text her all about google translator translated (Englich to German and German to Englich)
                          09-07-2024, 05:50 AM
                        • Robby-Gr
                          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                          by Robby-Gr
                          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                          Additional issues:...
                          09-27-2025, 12:02 AM
                        • Nairolf
                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                          by Nairolf
                          I have a Samsung DM32D display.
                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                          Here’s what I have tried so far:
                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                          08-24-2025, 03:47 AM
                          LCD LED TV Service Menu Codes
                          TCL LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          10-31-2024, 03:58 AM
                          09-06-2024, 11:40 PM
