Toshiba 42rv530u Firmware "Reset"
  • nwosolutions
    • Oct 2012
    I know this has probably been covered, but I have a Toshiba 42rv530u that does absolutely nothing when the power button is pressed. I have reason to believe it is the main PCB. Apparently there is a way of resetting the firmware by shorting 2 pins on an 8 pin IC on the main board. The power board is new.
    I stumbled across this thread: https://www.badcaps.net/forum/showth...rmware+toshiba
    and apparently tom66 may know which pins to short? I cannot find it in the service manual, assuming it is not there.
    I have never used this site before but hopefully you guys can be some help. Thank you!
    Re: Toshiba 42rv530u Firmware "Reset"
    I think the reset is for Samsung TVs. Not heard of it with a Toshiba before (I was guessing it might apply in that thread, but now I realise it probably doesn't), and it only works on older Samsung TVs for some obscure reason.
    • anlu
      Vestel Firmware - Toshiba 32W133DN
      by anlu
      Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
      Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
      02-04-2023, 12:59 AM
    • DarrenHD
      Firmware for older Toshiba TV 22CV100U
      by DarrenHD
      HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
      I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
      https://support.dynabook.com/support...tentId=2865076
      Thanks!
      06-16-2025, 11:56 AM
      09-06-2024, 05:27 AM
    • rblack711
      Need Firmware for Toshiba Model 42RV530U
      by rblack711
      Looking for the latest firmware file(s) for the main board (P/N PE0541, aka V28A000722A1) of a Toshiba model 42RV530U. I know it's a long shot. I still have to try.
      02-07-2022, 03:37 PM
      09-06-2024, 05:59 AM
