magnavox 42mf7000 -plasma - blue screen with single vertical white line on one side
  • gb77
    curious
    • Aug 2011
    • 76
    i have a magnavox 42mf7000 plasma tv that gives only a blue screen with single vertical white line on left side (opposite side of button controls). connecting to av1, av2, component, dvi, rgb & still gets blue screen. svid connected to av1 or av2 is sensed (screen shows [S] with av#). with vid/audio in av1, i can hear the audio for less than a second when i switch inputs (side panel button) to av1. after a minute or 2 the screen begins to flicker / shimmer like what you see when a pool is disturbed by some wind or such, & audio in av1 will still pop in for a moment when input is switched to av1, then nothing.
    i've fixed some lcds but never did anything with a plasma. read all the posts about philips/magnavox plasmas here & grabbed service manual for philips model 7320 which were in spanish. google search results talk about many lines, not just 1, but not seeing anything helpful. so i'm hoping someone has a quick idea to check, otherwise i'll take some pics & post them. thanks for your help.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: magnavox 42mf7000 -plasma - blue screen with single vertical white line on one si
    Check the caps on the mainboard near the main control ic. Also push on the ic to see if there is a bad connection. The blue screen throws me thou. Thought Philips magnavox have black screens on no input.
    • gb77
      curious
      • Aug 2011
      • 76
      it's definitely blue, and the screen shows the input source in yellow as it changes, and menus / volume / etc also show onscreen. the oddest part is i can go thru the menu and scan for tv channels - air - and tho it can't find any it does try (not an HD tuner) - but there is no coax or screw antenna connection accessible (the punchout isn't punched out). i expect i'll find something when i take the back off.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • Alicat
        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
        by Alicat
        Stopped by this site trying to fix my parents Panasonic Plasma TV.
        Model number is TH-50PZ85U
        Power comes on and the red power light stays on solid.
        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
        I also hear a few clicks.
        I also think my parents said there was a thunderstorm and the TV failed after that.
        Section 6 in the service manual talks about power and no screen,...
        10-30-2024, 10:09 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • ulthi
        Samsung QE50Q60TAU - Flashes black/blue screen
        by ulthi
        My tv is not able to turn on. I flashes between black and vague blue screen (see video)
        I have tried different resets and have also replaced the main board - but nothin has changed.
        Any suggestions?
        https://youtu.be/acYQ-ImmhWA
        10-14-2025, 01:48 PM
      • Zelek11
        Panasonic Plasma screen interference on left half of screen
        by Zelek11
        My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
        This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
        10-14-2022, 04:54 PM
