Faulty Samsung PSU (BN44-00427A) PD46B2_BSM
  • Mr_K
    • 106
    As said, i have a faulty Samsung PSU (BN44-00427A) PD46B2_BSM
    The main fuse was blown. All other fuses are fine. There is a short between + and - of the bridge rectifier (BD8015). I have removed both of the big coils to see if the short is on primary or secondary: Primary short after bridge rectifier is still present. But there´s also something wrong on the secondary side: e.g. Short over D3601. It´s not the diode....!
    Any advise on this one?
    Thank you for ur help!
    Re: Faulty Samsung PSU (BN44-00427A) PD46B2_BSM
    Check the MOSFETs for the PFC stage, one is likely short. Post some pictures and we can highlight the PFC stage.
    • Mr_K
      • 106
      Please check at Jimmys They have a nice one
      Edit: D3601 is in the top right corner
        This is an LED set? More and more of these are failing nowadays...
        Check the FETs I've highlighted for shorts; you may have to desolder the PFC ones.
        Depending on the topology, the D3601 -could- appear short even if it is OK. If you want, you can remove it from the circuit to test, but for now I'd say focus on the primary short.
          [accidental double post - please ignore]
          • Mr_K
            • 106
            First of all thank you for your quick support.
            One of the "lower" FETs (10NM60N) has a short. The other one is fine. The two other FETs (mdf9n50) have no pass in any direction. This seems a bit strange to me.
            And there is still a short at the diode. I made a mistake. It´s named D9601 not D3901. The one in the top right corner. The diode itself is fine. Even after removing all the FETs.
              Can you highlight the faulty one?
              If the diode itself tests fine out of circuit, then that is probably not a problem. The diode might in parallel with a low-ohm resistor, for example.
              • Mr_K
                • 106
                These two. Propably the red one, but im not 100% sure. I may have mixed them while measuring...
                  They look like they are paralleled; in which case, I'd say one failed would make the other look failed. If possible, remove them from the circuit and test. You should be able to run the set for a couple of minutes with the bad fet removed, as long as it didn't damage anything else.
                  • Mr_K
                    • 106
                    I already removed all the 4 FETs with the results posted above. I´ll try to get some replacement parts tomorrow and check the board.
                    • Mr_K
                      • 106
                      Ok, TV is working with the faulty FET removed. I was not able to find a replacement part today, so I have to order them. It´s 10MN60N May I replace it with a IRFBC40? This one is only capable of 6.2Amps.......
                        I wouldn't recommend it. Closest I can find:
                        http://www.digikey.com/product-detai...APBF-ND/812095
                        (9.2A rating, 0.75 ohm)
                        But NOT insulated! So you will need an isolating mica pad.
                        or http://www.digikey.com/product-detai...-E3-ND/2799082
                        • Mr_K
                          • 106
                          These are not easy to get for me.... Maybe this one?
                            The current rating is too low and the gate charge isn't specified. You didn't mention your country so I can't make suggestions relevant to you.
                            • Mr_K
                              • 106
                              Please check Reichelt I would like to order from them.....in germany.
                                Do you not have Farnell or RS in Germany?
                                • Mr_K
                                  • 106
                                  We have both of them. But i´d prefer Reichelt (i need to order more parts there) OR RS - not Farnell
                                    well, RS stock 'em;
                                    http://uk.rs-online.com/web/p/mosfet...633D424F544826
                                    • Mr_K
                                      • 106
                                      I recieved my FETs today and another problem shows up. With one FET installed the TV is running fine but as soon as both FETs are installed, the short comes back
                                        After removing the apparently shorted device does it test shorted out of circuit? Maybe there's a physical short on the circuit board, like a damaged trace or solder bridge.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
