Samsung LE32M86BD continuous power cycle
+ More Options
Posts
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Samsung LE32M86BD continuous power cycle
    This board only has two small BGAs on it: the Samsung DNIe engine, and a Micronas device. The Samsung relied just on the shield for cooling, the Micronas had a small heatsink attached with gooey thermal adhesive. There's another larger chip under a heatsink but that's a QFP package.
    I decided to reflow the Micronas. The board is cooling now, we'll see what the outcome is. Edit: Same thing. It's marked as "OPTION" in the service manual anyway... On the other hand, i pressed with my finger on the DNIe engine (didn't bother to put the shield back on the board), and it stayed on after just a minute of being powered up. Garbled screen tho. So, the DNIe engine BGA is up next. Funny thing is - the DNIe chip barely gives out any heat.
    Edit 2: Finished with the DNIe too. Powered up first time, but stupor: Garbled screen. Heating up the board while it is working and power cycling the set afterwards brings the picture nice and clean. So the power issue and the garbled screen issue aren't one and the same. Grr. I'll now heat the devices one by one using a smaller nozzle, and see which one is buggy. The only one left is the big TQFP... Or maybe that crystal oscillator on the board is bad... We'll see.
    Edit 3: Not entirely sure as i got pissed and removed the smaller nozzle and heated the whole board, but it went like this:
    • TQFP to 80 deg C? Garbled.
    • Micronas to 80 deg C? Garbled.
    • DNIe to 80 deg C? Garbled.
    • Whole area, including TQFP, Micronas and SMD electrolytic capacitors to 80 deg C? Running in spec...
    Stupid capacitors. Gonna pull them one by one and check for ESR.
    A working TV? How boring!
      Bad SMD Samwha/Samyoung too? Samsung, you disappoint!
      The "Samsung DNIe" is likely just the main image processor SoC (it's also going to have the main processor on it) so very important for the image. I doubt they dedicate an entire ASIC to silly contrast/brightness/sharpness adjustments... On the LE32N73 it had the DNIe processor, as well as a main MICOM and sub MICOM. Sub MICOM was responsible for power up, error detection, IR, LED. Main MICOM communicated with DNIe to add OSD etc., it handled video switching and sync detection for VGA. Not sure why the sync detection was done on the main MICOM though.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        ... Nope. Caps tested good, replaced and still the same. Either garbled, or just entirely blank screen on power up (like the Tcon is left unconnected).
        I found the board for sale for $45. Messaged the owner about it.
        • tibimakai
          • Jan 2012
          • 3680
          It may or may not be the same problem, I'm just throwing it out there.
          I just had a different Samsung LN-T375 and had the same symptom and ended up being the panel. When I disconnected on of the four ribbons going to the panel the TV powered up. Before that was just power cycling.
          Found blown chip on the T-con, Tom66 said that it's the gamma chip.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Since this one did the same when i unplugged the Tcon, before reflowing the BGAs on the sub board, we can rule that out. It's definitely the sub board here.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              #26
              Got a message from the owner, he said he doesn't want to buy the board, because the board isn't for sale locally and can't be tested before buying.
              I'll offer him $60 for the whole TV as-is and buy the board myself. I think he'll accept. I have a firm offer of $170 for this set already, so that would be $65 profit which isn't bad.
                I hope you can fix it. It would be interesting to see if it is that board at fault, I hope it is. Your first LCD TV repair? Once you start... you can't stop!
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  #28
                  Well, he doesn't wanna sell it. Or rather, his father doesn't, it's his TV. Put it back together. The good news is that it works fine after a while just like before, so i won't have any "you broke it" comments.
                  Edit: Entered factory mode. Panel on time is 17450 hrs.
                  • PinkFloyd
                    • Apr 2019
                    • Serbia
                    #29
                    On the T3 board, French-**** sign on top, top right on open TV set, model LE32M86BD Zou have electrolytic 1uF, only one, on edge, which You will measure that is OK.
                    - CHANGE IT! And try power on.
                    p.s. It is crucial for oscilator and power 3.3V which returns signal to main MB.
                    Probably going on breakthrough in mS.
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
