Samsung PS42A456P2D Help!!!!
  • danjcarr1
    • Jul 2012
    • 35
    • Uk
    I have a Samsung PS42A456P2D that I am attempting to repair.
    The Fault
    The tv turns on as normal and displays the picture fine. Then after about 10 secoonds it turns itself off then back on. And repeats this process over and over.
    Has anyone ever came accross this problem with this model of tv?
    Any help would be greatly appreciated.
    I have also tried a psu that I know works and the fault remains, So I know the fault is not with the psu. Was thinking maybe X or Y sus????
    Thanks Dan
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
    09-07-2024, 05:50 AM
  • Egidio85
    Samsung UE55F8000SZ Turns on and off immediately
    by Egidio85
    good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
    This defect happens continuously, hearing the classic click of the relay every time.
    Power supply board BN44-00636B
    disconnecting the mains and lamps from the power board always causes the same problem.
    Is it normal that without anything connected this power supply turns on and off cyclically?
    any suggestions on what to check?
    thanks in advance
    03-11-2025, 12:45 PM
    09-06-2024, 11:40 PM
