42LG3000 LG Television
  • Berts
    • Aug 2012
    • 55
    • Scotland
    Greetings,
    I am new here so would just like to say hi.
    Please could someone offer some advice on a LG 42LG3000.
    I usually fix computers so this is a first for me.
    The TV powers on fine, back-lights are good. A picture can be seen but unfortunately it jumps all over the place but only on the vertical axis.
    I have googled around and found white screen / black screen problems, but nothing on this flickering and jumping picture.
    Any ideas? I will of course try and help some people in the computer section so you know I am not just a newbie freeloader!
    Thanks in advance for any ideas / advice.
    Bert
    Re: 42LG3000 LG Television
    I would guess a noisy voltage regulator. I have a TV right now giving the same issue and it is a voltage regulator which is oscillating due to bad capacitors near it.
    https://www.badcaps.net/forum/attach...1&d=1344693073
    https://www.badcaps.net/forum/attach...9&d=1344693073
    • Berts
      • Aug 2012
      • 55
      • Scotland
      thanks for replying.
      Would you suggest replacing the power board?
      I cannot see any signs of bloated capacitors.
      Berts
        No, check the main board first. Post pictures.
        • Ady2017
          SMD fuse soldering advice please
          by Ady2017
          Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
          11-07-2025, 12:03 PM
        • chazzo
          CH341 programmer advice, including jumpers seemingly reversed
          by chazzo
          I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
          [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
          I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
          10-12-2025, 08:15 AM
        • Jidis
          Need T-Con Advice (Vizio P602ui-B3)
          by Jidis
          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
          09-22-2025, 05:10 PM
        • zlr8r
          Advice on newer EC chip programming eg. MEC5107-LJ BGA
          by zlr8r
          Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
          i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
          09-16-2025, 09:54 AM
        • Borse2008
          by Borse2008
          • There’s
          07-15-2025, 04:55 AM
