LG 50PG20D No picture but has sound, almost fixed but one last question
  • harts
    • Aug 2012
    • 10
    Hi all, I have one last question on the repair of my TV but first a little about what I have done.
    My Plasma tv was working fine and is only 3 years old and a couple of nights ago the screen went blank but the sound remained, it took my 20 seconds to realize that it wasnt good, remote worked just a black screen and completely black.
    I pulled the back of and started to look for obvious problems, I couldn't find or see any so I tested the power supply voltage and all good, all fuses when good, no loose connectors or anything so I did some net surfing and reading here. After that I pulled of the Ysus board and tested all the transistors/fets and all tested fine, had a look over the buffer boards and also all looked fine but im not sure how to test those. I the when to the Z sus board and found 2 shorted IRGP408 transistors, everything else seams fine so I went out to our local TV repair guys to see if they had stock and they didnt, the first told me that would be the problem for sure and the second told me I would need to replace all the boards as it very uncommon for just one to go, they said if the y sus was working I should see something on the display.
    So my question is is it common for all the boards to die at once, I had trouble finding another topic where this had happened or do I just take a shot at ordering an $80 board. To replace all the boards it would be around $300 and with a panel that is 3 years old and only HD im not sure its worth it. Any suggestions would be great, I will put up a pic of the inside of my TV.
    Thanks Jared
    Re: LG 50PG20D No picture but has sound, almost fixed but one last question
    In general with a bad Z-sustain you'll get a poor picture but enough to see the Y-sustain is working. However, it is possible that the Z-sustain is overloading the power supply; so try unplugging the power connector and seeing if it shows a dim/blurry picture.
    • harts
      • Aug 2012
      • 10
      Ok I gave that a go and still nothing at all
        Even in a dark room, no glow from the screen? Did you turn the TV off before unplugging it?
        • harts
          • Aug 2012
          • 10
          yeah nothing at all, I had the power off while connecting and dis connecting, im scare of the voltage that lives in there
          The fisrt 2 times I turned it off and on after it died and before I pulled it apart there was a slight glow for a second or so when it was turned back on. Im thinking all boards may be bad or even the panel may have died.
            Okay, do you have a digital multimeter?
            • harts
              • Aug 2012
              • 10
              yeah sure do, If it helps to know I have a little knowledge with electronics at the circuit board level also, I can diagnose faulty transistors and a few other components. I also repair pinball machines for a bit of fun, there a better mix of electronic and mechanics though
                OK, so can you test the Vs voltage? There should be a place marked "Vs_TP" on the power board, or you can test on the pin connector itself. Careful it is around 200V.
                • harts
                  • Aug 2012
                  • 10
                  I did test the power supply Vs and Va and they where at 60v and 194v but that was on the power supply side of things, I will test and see it its getting to the sus boards, thanks for the advice its been great!!
                  • harts
                    • Aug 2012
                    • 10
                    My Y sus has a spot that looks like another connector for the power supply should be mounted there right beside the actual power connector, I tested continuity between the connector and the blank and they are connected in parallel so when the tv is on vs is 194 and va is 60 as per specs on the panel, 5v is also good. I didnt plug the z sus back in as i have removed the components but tested the pins and all are good.
                      That sounds good, my guess would be a control board issue as it is responsible for driving the Y sustain and Z sustain boards and if it went wrong it could have caused the Z sustain to damage itself. I don't suppose you've got a scope?
                      • harts
                        • Aug 2012
                        • 10
                        No I dont have a scope but I have access to one, im not sure that its a very good one though. What would I be testing on the control board?
                          You would need to test that drive signals (that would go to the sustains) are being generated by the control boar. If they aren't I would suggest the control board is at fault.
                          • harts
                            • Aug 2012
                            • 10
                            Cool, I guess if I find a service manual it will tell me the volts and the frequency im looking for. I will find out the specs of the scope my boss has and give it a look. Thanks again
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • i_am_patch
                              Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                              by i_am_patch
                              Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                              04-30-2024, 08:20 PM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:30 PM
