Samsung FP-T5084 - Solved one problem, now have another (Clicking, Blinking LED)
  • jb8
    Re: Samsung FP-T5084 - Solved one problem, now have another (Clicking, Blinking LED)
    I think I have the same issue as the OP.
    Samsung FP-T5084 no video or audio with clicking sound when connected to AC. The clicking sound cycles about 3x then silence. I also noticed that the front power LED indicator is red and blinks on for 5 sec then off for 2 then repeats that cycle.
    I checked the fuses on the PS and all of the 3 fuses are intact and not blown nor do I see any bad capacitors just from checking visually.
    I removed the cable from the Y-main board to the PS to isolate. Same issue. Similarly, did the same with the X-main board. Same problem.
    I also replaced 4 x 2200uf 10v capacitors on the PS with 2200uf 25v capacitors with no change in the symptom.
    Before I replace the PS, any other tests I need to do? I do not quite comprehend some of the instructions on the thread and I apologize for that.
    Thanks to all.
    • Schorsch87
      • Feb 2013
      • 55
      I have the same issue with like Viking. On standby line I just measure 3.23V. And i also found out that the SL432 Shunt is the problem. Somebody there who can help me build up a ne flyback curcuit as viking has done. I need the items and schematic so I can build it up.
      regards
        You could just replace the shunt IC with the original -- may be available from a supplier -- OR, you can use a TL431, if you double the current resistor going from REF to GND.
        • Schorsch87
          • Feb 2013
          • 55
          The original Shunt isn't available here. Thats why I'd like to switch to TL431. I doubled the resistor from Ref to GND and it doesn't work. Maybe i have to measure again. I will reply on the next weekend.
          Regards
            You may have issues different to the previous poster.
            • Guppstah
              • Feb 2013
              • 16
              Originally posted by tom66
              Those photos are fine.
              The left board (looking from the back) is the Y-main board. It connects to the plasma panel thru the buffer boards. The right is the X-main board.
              There is a large power connector going from the power supply to the X-main board. If you disconnect this, does the TV stop clicking? With the X-main disconnected, you will get a picture, but it will be quite poor (usually dim, slow to change, and sometimes purple-tinted.)
              Sorry to hijack, but this is my exact symptom.
              If I turn the Samsung 42" TV on, I just get a clicking relay.
              However if I disconnect the x main board, no clicking and the TV tries to turn on, startup sound and everything but a picture.
              Does this mean the x main board is faulty?
              Any help greatly appreciated.
              Garry
                Yes, though you should usually get a visible, but poor quality picture (it will be very dark, check in dark room to see if any panel light is visible.)
                • Guppstah
                  • Feb 2013
                  • 16
                  All I get is tiny flickers, like stars all over the screen.
                  • Guppstah
                    • Feb 2013
                    • 16
                    I have sound, if that makes a difference.
                    • Guppstah
                      • Feb 2013
                      • 16
                      Ok I have two main connections to the X main board, if I have both connected I just get the the relay clicking, if I disconnect either (one to Y main & the other to PSU) the TV turns on and I get sound but no picture. Does that help at all?
                      All help appreciated as I am recently unemployed and now without a TV, all going well......not
                      • Guppstah
                        • Feb 2013
                        • 16
                        New x main stopped the clicking and allowed the TV to turn on, but unfortunately still no picture. What's next to look at please?
                        • Guppstah
                          • Feb 2013
                          • 16
                          Replace ymain and y buffer boards?
                          • sbbamafan
                            • Mar 2013
                            This is the thread that won't die. I am new here and to TV repairs in general. I got a FP-T5084 from a friend. The tv is not working. The power on LED is red and the blue logo on the bottom lights up and the makes the little power on noise (three notes) but nothing else - no picture and no sound.
                            I checked all the fuses and capacitors and found a bad capacitor (on the Y board, I believe) that I replaced. There was no change in reaction.
                            Someone (not a very knowledgible someone) told me it was the main board. I ordered one from Ebay and it arrived tonight. It seems worse. Now it just clicks over and over and over without stopping. The sound of the three notes does NOT happen any more either. The LED is not on nor is the logo lit.
                            Is this board bad, both of them or is there another problem??? I truly have no idea what I am doing and really hate to toss this in the dump but I am not going to spend much more money on a potentially wasted wild goose chase. I really appreciate your help. Thanks in advance!
                            • Schorsch87
                              • Feb 2013
                              • 55
                              Hi again,
                              now I used an old nokia mobile charger to power up the standby line. With a good result. The relays are clicking. Now the bad part. There's a tiny board which tells me an error code. The led blinks 8 times what means TH_DET. What does it stand for?
                              regards
                                It's possible that without the other rails the standby supplies, it cannot work properly and will throw an error code.
                                • Schorsch87
                                  • Feb 2013
                                  • 55
                                  I've connected the AC cord properly to the power supply and in addition to this the 5V charger to get the standby curcuit work.
                                  I read something about the IC1803 on the Mainboard. I tried resetting this one, but this didn't help.
                                  The error code comes up when I connect the mainboard to the power supply.
                                  I'm really getting mad with this smps -.-
                                    What I mean is the standby circuit can sometimes provide more than 5V, even though you might not normally see it. Sometimes it can provide power to other parts of the SMPS like the PFC and PWM ICs.
                                    • newport man
                                      • Apr 2013
                                      • rivera
                                      #58
                                      Hi!
                                      Everyone
                                      I used have the same problem, when I power up the tv it just click and blinking
                                      Light, until I remove the back cover and start checking for any bad
                                      Capacitor and nothing all since to be fine then start checking
                                      The fuse and I found a blow out fuse on the Y main board
                                      I replace the fuse now when I plug the tv and turn on now it click like 7 time and the flashing light still on
                                      Now I going to trying the troubleshooting
                                      I will keep you post it
                                      • deek
                                        • May 2014
                                        #59
                                        hi i to have this set in my work shop BN44-00175A POWER SUPPLY this came in with for bad cap on the power supply so change them now i have no 5v + rail for the start up does the sl432a go sort ???
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
