Le37a558
  • doncia
    • Jul 2012
    • Malta
    Le37a558
    Dear friends,
    This my first thread and hope there will be more in the future. I have a Samsung LE37A558. The picture is OK when switched on, however it gets darker with time. When the set is switched off and on again the picture appears and then fades off within a minute.
    Thanks to all reading this thread.
    doncia
    Re: Le37a558
    It sounds like an LCD panel fault, but it could be a T-con board fault.
    • senndogg
      • Dec 2011
      • 383
      • Albania
      Re: Le37a558
      it seems to have a Samsung panel. very notorious one. best thing would be swapping another t-con into it, just to rule this out if the problem persist. may be also a tab issue.
      • doncia
        • Jul 2012
        • Malta
        Re: Le37a558
        Thanks for your interest,
        Some new developments on the same problem, when the set was left with a dark picture (by mistake it was so dark I thought it was off), I found a nice bright picture. The more I work on this LCD the more I feel as if starting the profession from scratch.
        Regards
        doncia
        • senndogg
          • Dec 2011
          • 383
          • Albania
          Re: Le37a558
          good for you. you should begin stripping it down if you have enough space. consider that you might have to leave it open for days during troubleshooting.
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
            09-07-2024, 05:50 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Dodgethis
            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
            by Dodgethis
            Hello all,
            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
            09-11-2024, 07:39 AM
          • YellowJacket
            Samsung QE55Q60RAT - no picture
            by YellowJacket
            Hi friends,
            a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
            07-30-2024, 01:31 PM
