Toshiba 46RV530U screen ghosting
  • ntehicks
    • Mar 2011
    • 272
    http://www.youtube.com/watch?v=VvFWl...=1&safe=active
    I have this Toshiba 46" lcd tv that was given to me. when you turn on the tv the right side looks great and works great but the left side has shadowing and fades in and out. I was thinking of replacing the T-con but wanted to get another opinion. is there some trouble shooting steps that I could do to see if it is the TCon.
    Re: Toshiba 46RV530U screen ghosting
    Failed panel. Common with 46" and 52" based Samsung LCD panels (which your TV probably uses.)
    But it is fixable most of the time. http://www.youtube.com/watch?v=zW998RTAq-0
    • cliff_hootarski
      • Jul 2006
      • 411
      Does the picture change if you flex the TV frame?
      If it does, it's a tab bond issue. I just fixed my Toshiba
      (with bad tab bond issue) by using thick double sided
      tape two layers deep. My bad tab was the upper right one.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
        09-06-2024, 05:27 AM
      • sigmeyer
        Toshiba 50UL4B63DG faulty screen?
        by sigmeyer
        I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
        08-30-2025, 08:13 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
        09-06-2024, 05:59 AM
