Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
Oh, and once I find a 100W globe, when I power it up, should I have all the sub-boards connects to the power supply?
I found this thread (and some other) so exciting and tense like a good book ;-) What will happen next? Who is the bad guy, victim or the killer?! We have some usual suspects here, lot of victims, actually it's double murder for now. Clues are scattered all over 50 inch crime scene!! Maybe it's time to call fancy CSI chicks to take a look ;-)
Well, I hope it will be a happy ending. I'm also waiting for IPM delivery for my 42" repair from other thread. It usually takes 15-30 days for stuff to come to Croatia... It will be a long wait. Till then, I wish you luck!
Cheers!
SuadLeave a comment:
This power supply has two fuses though, F801 immediately adjacent to the AC input, and F803 which is near the mosfets that I found blown.
I also read about failed startup caps causing high voltages and blown parts, so I'm thinking that as I have replacements, I'll replace all the caps I can on the hot side of the power supply.Leave a comment:
That is really good considering that includes the July 4th holiday. One of my ebay orders from the USA has been stuck in the sorting facility for 5 days now due to the July 4th holiday. :-(Leave a comment:
https://www.badcaps.net/forum/showpo...07&postcount=7Leave a comment:
FYI, When you first replaced the Mosfets, probably the reason they failed while you were away from the set is that Samsungs remember the current power on setting. If unit was on when it failed, as soon as standby power comes up, unit will attempt to turn itself on. It probably turned on while you were away from the set and blew the mosfets.Leave a comment:
Before you blow some more FETs test it with a 100W light bulb in series...Leave a comment:
Well my 1SS184 diodes arrived today - got them installed, but can't test it out yet as I had removed to 20 ohm and 10k ohm smd resistors for testing, and in the process or replacing them I busted one 20 ohm resistor and lost another one. Fortunately, I had already ordered replacements which should be here any day now!Leave a comment:
I hadn't mentioned it before, but there were 3 25v 680uf caps that were swelled/leaking on the X & Y main boards - replaced them today in anticipation that my diodes/resistors can't be too far away. They were well and truly knackered - ESR meters reports < 100uf and > 6 ohms. Oh and they were Samwha'sLeave a comment:
Any news on this repair?Leave a comment:
I hedged my bets on the 1S184 diodes - I found some in Thailand with expedited shipping today - Only $US6.50 so I should soon have a plethora (well 60) of them.Leave a comment:
Canada and Australia are almost in the same boat when it comes to buying stuff online. I wait up to 60 days for my stuff to arrive, but I get it at very good prices. I try to anticipate my needs well in advance.Leave a comment:
PS if you don't have easy access to 1SS184 diodes, I should soon have plenty of themLeave a comment:
by porfyriadhsHello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
Thanks a lot !! -
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... -
by CDNBrewerHello, I have a Samsung Plasma TV - Model # PN43D450A2D
This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by crigabHy guys, i have a Samsung plasma PS43E490, with Y-board and X-board defective. I repaired them, but now the problem is that i have sparks on the ribbon cables from the X buffer to the screen when powering up. There is any solution for this? Thanks. ...
- Loading...
