50" Samsung Plasma (model number PS50Q91HD) - possible purchase
    replied
    Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
    Someon's just contacted me about their Samsung PS42C7HD clicking - I might take a chance on it if it's just cold joints.
  • psmedley
    replied
    Originally posted by tom66
    If it helps, I *think* this is the schematic for your PSU.
    The correct schematic is at
  • psmedley
    replied
    Tried to reply on Saturday but server upgrades got in the way
    All transistor readings were higher than 30 ohms, so I'll assume the sub boards are OK.
    I do plan on replacing the accompanying resistors as well as the diodes and mosfets before I try powering up again. ie all the parts described in http://www.ebay.com.au/itm/160644626388
    I just need to wait for all the parts to arrive now - Adelaide electronics stores suck
  • retiredcaps
    replied
    I just do a simple all pins combination to see if they are shorted. For a 3 pin transistor, measure the resistance between pins 1-2, 1-3, and 2-3. Any reading under 30 ohms warrants desoldering and verifying out of circuit.
  • psmedley
    replied
    I didn't get a chance to actually turn the TV before it shorted. I plugged in the AC, it wasn't clicking, so I made a quick pit stop, came back and it was clicking
    Any tips on testing the Q's?
    Is:
    <quote>
    POSITIVE PROBE TO: -----NEGATIVE PROBE TO: -----RESISTANCE READING-- CONCLUSION:
    Emitter------- -- Base---------- Less than 150 ohm ------Transistor is NPN
    Base --------------Emitter --------Infinity ----------------Transistor is NPN
    POSITIVE PROBE TO: NEGATIVE PROBE TO: RESISTANCE READING: CONCLUSION:
    -Emitter------------Base ---------Infinity ---------------- Transistor is PNP
    Base --------------- Emitter --- - Less than 150 ohm ------- Transistor is PNP
    Some defective indications of transistors: Resistance between any pair of the terminals is less than 10 ohms* means that the transistor is shorted. Resistance between base and emitter or base collector for both the forward and reverse application of ohmmeter probes is infinity (meter needle don't deflect)* means that the transistor is open. Transistors overheats (except power transistors) during normal operating condition means that the transistor is shorted.
    </quote>
    Sufficient?
    replied
    Q's and D's can be tested; R's will need to be pulled.
    Did TV show any picture before it shorted again?
  • psmedley
    replied
    OK ordered the SMD diodes retiredcaps suggested.
    Whilst I wait for them to arrive, I've been reading http://preher-tv.blogspot.com.au/201...-repaired.html on the other common issues on similar Samsung power supplies.
    This mentions components like:
    RX802, RX803, RX832 and RX833 are open or have a seriously increased resistance.
    RX804 and RX805 are open or have a seriously increased resistance.
    These all measure around 50 Ohms in circuit vs the stated values of:
    RX802, RX803, RX832 and RX833= 20 ohm
    RX804 and RX805= 10k ohm
    Is this due to them being measured in circuit??
    It also mentions problems on the sub boards:
    QS803, QS804, QS805 and QS806 one or more shorted(check for open junctions as well)
    DS823 shorted(may be open as well) check between pin 1 and 3
    RS859 may be open or have a seriously increased resistance
    Can these parts be tested in circuit?
    QS803 and QS804= NPN 20V 2A SMD BJT(marking ZG)
    QS805 and QS806= PNP 20V 2A SMD BJT(marking ZH)
    D823= 18V 0.35W SMD zener diode(marking 8Y)
    RS859= 4.7 ohm SMD resistor
    Cheers,
    Paul
  • psmedley
    replied
    My only hesitation is the shipping time from the us to australia
  • retiredcaps
    replied
    Originally posted by psmedley
    They have a list of 'similar' products - any recommendations?
    Need 48 spare? 50 for $6.00 + free shipping
    http://www.ebay.com/itm/160586650557
  • psmedley
    replied
    http://preher-tv.blogspot.com.au/201...-clicking.html suggests "DS801 and DS802 are both 1SS184T5LFT, UFR dual package common cathode SMD diodes" I find these on mouser at:
    http://au.mouser.com/ProductDetail/T...sljcLw5w%3d%3d
    However RS in Australia has this as a discontinued product:
    http://australia.rs-online.com/web/p/rectifier/3174558/
  • retiredcaps
    replied
    Numbered left to right - 1 to 3 - pin 2 is on a side by itself
    The diodes are definitely bad "in circuit". You can remove them and verify out of circuit. You will have to remove them anyway if they are bad.
  • psmedley
    replied
  • retiredcaps
    replied
    Next question will be any tips on replacing SMD diodes???
    CuriousInventor makes an excellent series of soldering videos.
    http://www.youtube.com/watch?v=3NN7UGWYmBY
  • retiredcaps
    replied
    How are you numbering the pins? If pin 2 is the only pin on one side, those diodes are definitely shorted. That means pin 1 and 3 are on the same side. If yes, both diodes are shorted.
  • psmedley
    replied
    DS801: (first pin red, 2nd black)
    Pin 1-2 = 0.006v
    Pin 2-1 = 0.006v
    Pin 2-3 = 0.006v
    Pin 3-2 = 0.006v
    DS802: (first pin red, 2nd black)
    Pin 1-2 = 0.006v
    Pin 2-1 = 0.006v
    Pin 2-3 = 0.006v
    Pin 3-2 = 0.006v
    So given in diode mode the reverse reading should be open loop I'll say these are bad?
  • retiredcaps
    replied
    can anyone explain how to test DS801/DS802? it has three pins - not sure how to identify which pin is what.
    I get ~10Ohms across the pins and reversing the red/black gives the same value - so I'm assuming they're shorted? as being a diode they should be open circuit the other way around?
    If the diode looks like this -><-, treat it like 2 separate diodes when testing. That is, pin -> is one diode and <- is the other.
    Put your multimeter in diode test mode. Measure pin 1-2, then reverse the probes. Measure pin 2-3 and then reverse the probes. You should have 4 readings in total.
    In diode test mode, the unit of measure is volts, not ohms. So instead of 10 ohms, you have 0.10V (10 mV). That would be a shorted diode.
  • psmedley
    replied
    Reading http://preher-tv.blogspot.com.au/201...-clicking.html - can anyone explain how to test DS801/DS802? it has three pins - not sure how to identify which pin is what.
  • psmedley
    replied
    uggh mosfets finally arrived from RS today.
    Installed them, plugged in tv - yippee - only one click from psu. Went for a quick pit stop, came back and the fuse had blown and the new mosfets are shorted Turns out I'd forgotten to tighten the screws securing the mosfets to the heatsink - however I wouldn't have thought being in standby for a couple of minutes could be enough to blow them???
    replied
  • psmedley
    replied
    Well given the packaging - farnell don't have a suitable replacement... So... it was either ebay from China, the US or the UK, or RS with the parts on backorder.... (and maybe from the UK)
    Just wish Jaycar sold mosfets so I could get something today :P
  • porfyriadhs
    Samsung Plasma PS51D6900DS Bootloop
    by porfyriadhs
    Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
    Thanks a lot !!
    10-19-2023, 11:31 AM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
  • CDNBrewer
    Samsung Plasma PN43D450A2D No Power
    by CDNBrewer
    Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
    This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
    I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
    When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
    03-02-2025, 04:59 PM
    09-07-2024, 05:50 AM
  • jshhh
    Samsung ps51d550 plasma tv repair help
    by jshhh
    I have an old Samsung ps51d550 that would power on with no picture. I was testing the voltages on the boards based on some advice I'd seen online, I took off 2 of the boards to try test the mosfets, but couldn't really get at them...I left it a while, came back and reinstalled the boards to do some tests and it started smoking. Looks like it was coming from this ribbon cable (see attached picture).
    As you can see, im an absolute novice with this kind of thing but I don't like paying for repairs or buying new stuff if I can fix it cheaper.
    do you think...
    07-19-2025, 10:18 PM
