This guy has an RCA 42PA30RQ
    Re: This guy has an RCA 42PA30RQ
    Oh by the way, I'm not sure if this was effectivepower but this is what I did with the old board. I connected 5v to the y board with my variable power supply. The board started Smoking from one of the zendiodes located near a power ic. It started smoking at 2 volts
      I meant Effective not effective power
        All of the IC chips did not heat up or burn just that one zen diode
          Have another Y-main on order. Seller refunded me my money. I hope this next board is not defective
            waveform from control board y-main ribbon connection.
              A photo of the Zen Diode that smoked when I tested the Y-Buffer with 10-15V with my variable power suppply. The zen diode started smoking between 2- 4 volts...Upon applying power to the board, I immediatly noticed the current shoot up fast..clearly an indication of a short on the board.
                If you need any measurements I have one of those boards here.
                  Sure would like to see them. Thanks for offering Tom
                    I will see what I can do.
                    My board is defective though, when the Wii controller smashed into the working TV it shorted some panel electrodes together (which have alternating ~200V or 0V), which damaged two of the buffer ICs. I am now suspect of any buffer boards from broken TVs as they may have been damaged. Newer plasma panel uses very thin panel structure (<5mm), meaning shorts are more likely.
                    So I may have to limit my tests to around other components, I cannot supply measurements for those ICs.
                      Ok sounds good. Any measurments you have is a help
                        I tested the new Y-Buffer board and there are no shorts. I also tested the old one and there were no shorts. I followed your video instructions. However, when I supplied voltage, the current draw was increasing fast and then the Zen Diode smoked.
                          replacement X-Main, control board, and In and out board just arrived .
                            Just did same model with same trouble
                            Had shorted fet's on main Y and X boards
                            Replaced both boards set works
                              I did replace the Y-Main and Y-Buffer and no fix. So I figure I recieved a defective Y-main and ordered up another one which I have not recieved yet. But I just replaced the control board and connected the ribbon cable to goes to the Y-main to see if the Vs and Va drops on the PSU after power up and it still does. without the ribbon connected the voltage is stable vs 207v Va 57v
                                I'm just going to have to wait on the Y-Main board to arrive next week.
                                  Tom what zed diode goes to ZD5400?? On y buffer board.
                                    Shoot. Sorry I'm not in Leeds any more and I left the buffer there, I forgot. I'm back in 4 weeks. Sorry.
                                      Just got my X-Tronic 4040 rework station....Love this equipment it makes soldering and due soldering SMD and SMT so much easier. And it's ESD safe. Now I can test some of the SMD components out of circuit. Back to working on my RCA 42PA30RQ.
                                      X-TRONIC" MODEL #4040 - 4000 SERIES - SMD - ESD SAFE - 2 in 1 Digital Hot Air Rework & Soldering Iron Station - 4 Hot Air Nozzles - 10 Asst. Solder Tips - 1 Extra Hot Air Heating Element & 1 Extra Solder Gun Heating Element - 1 5X MAGNIFYING LAMP!!!
                                        Yes, that looks pretty nice and good price! $139 at amazon. I'm jealous
                                          Well I swapped the PSU on the TV, out another $50 and I still have not been able to get this tv going..
