Issues with sound buzzing on occasion.
  • JeffJ
    • Apr 2012
    • 189
    I have a vision quest 42" (which is just a re-branded poloroid) I know they are prone to failure, but its a spare tv for the bed room.
    Anyways, I opened the rear panel to clean it out, saw some blistered caps on the power supply, so i pulled it out and replaces 70% of the caps as most of the ones that were not blistered tested very bad on my capanalyzer, some of them being completely open circuited.
    I know megmeet power supplies can cook your bacon, and i've recapped it with all high quality Panasonic caps i had at work.
    Any ways does any one have an idea for the sound buzzing, when it happens its for a good 15 seconds then it stops and normal audio resumes. turning the tv on and off also fixes it. Some times i can go weeks andi t will not buzz some times it will happen once a day. and only once did the buzzing not stop until the tv was powered off.
  • jjne
    Yamaha RX V675 sound issues
    by jjne
    I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
    From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
    At first I thought it was either a speaker relay or the DSP, but I don't think...
    06-24-2025, 07:01 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • acedogblast
    Marantz SR5012 popping and other sound issues
    by acedogblast
    Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
    These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
    I have disassembled the unit and was able to take out the...
    02-15-2023, 01:40 PM
  • valente222
    LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
    by valente222
    Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
    11-18-2024, 03:21 PM
  • i19
    Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
    by i19
    Hi
    I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
    Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
    I want to use an CH341A (new model with 3.3v) to flash it.
    My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
    Any tips on how to connect to it? Maybe something...
    08-20-2024, 06:50 AM
