if the zsus ribbons are removed from the display can you check the display for a short with a meter? anyone know the answer, and if so is it the two outer connectors(far each side wide).
hitachi display question
Re: hitachi display question
No, I don't think so. There are too many connections to check anyway (Y buffer connections, for example.)
However, you will be able to see a picture if the Z-sus is faulty, but it will be dim, deep-purple ish and slow to change.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
thanks tom, i cant find any info on it the digital board seems to be where it is but 150.00 for a board and if it turns out to be the display i would be sunk. i have followed the service manual to the point where it seems to leave you in midair. i cant even find a schematic to try and turn on the backlights. has to be a way to light it, something cuts the danged thing on,probally a transistor on the zsus. how does the digital board determine the short anyway. the voltage out of the ps holds steady va and vcc when it get the 5.1 volt return signal from the digital and logic controller. i know the logic is good,however when all is hooked up i cant get the 5.1 needed on the return.Comment
I've never heard of plasma panels shorting. Only driver boards.
The short circuit is detected by the PSU because the load is excessive and it goes into protection mode. Rarely is there a fault signal going to the main board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
tom, would you spend the money on the digital board and take the chance? serouisly. there are a couple on ebay but i am afraid of them, you usually get what you pay for and they probally aren't working anyway. tried to find a local trade for some of the good parts i have here on hand, seems no one local ever has what you need until you don't need it anymore. good case of murphys law. thanks deweyComment
What is the model of the TV? I would get the scope out and check, but I'm guessing you don't have one...tom, would you spend the money on the digital board and take the chance? serouisly. there are a couple on ebay but i am afraid of them, you usually get what you pay for and they probally aren't working anyway. tried to find a local trade for some of the good parts i have here on hand, seems no one local ever has what you need until you don't need it anymore. good case of murphys law. thanks deweyPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
yes i do a 150 meg 2430a tektronix. but where are you going to start the va and vs wont hold like it is. i am wary of putting voltage thru the pins to keep it running while the rest of the set is powered on. the return signal is lost somewhere in the digital board. i have checked every component on it i could by meter, vom, esr, diode tester, transistor tester. could even be a failed processor it seems to be running pretty hot but i dont have anything to compare tooComment
Check crystal for the MCU.yes i do a 150 meg 2430a tektronix. but where are you going to start the va and vs wont hold like it is. i am wary of putting voltage thru the pins to keep it running while the rest of the set is powered on. the return signal is lost somewhere in the digital board. i have checked every component on it i could by meter, vom, esr, diode tester, transistor tester. could even be a failed processor it seems to be running pretty hot but i dont have anything to compare too
Check waveforms stay, however briefly... if they appear almost zero all the time then there is a short!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Your panel is fine. P50H401 is what you have.
The fault chart will normally get you pointed to the correct board that needs replaced.
I have only had two tvs that gave a dim picture with a faulty Z board. (L/G only so far) Mostly no picture will be the issue as with the failed y and/or buffers.
If this tv had a failed y or z or buffer board you would not get audio and the tv will shut down after about 2 seconds.
There are a few boards that tie into the power supply.
There should be a small board about 6" square just to the right of the mainboard.
Behind the mainboard there should be a timing or control board that feeds the y,z and x driver boards. (rare to fail)
I have never had an issue with the x (lower boards) on these tvs but I would not rule them out.
Again, the number one failure on these sets is the y buffers then the y drive board and the power supply.
What kills these tvs is people messing with them which makes it hard to repair by the time we get them.Comment
the y drive checks out according to the flowchart and vom test, so does the z, power supply if i furnish the 5.1 volts needed stays up. it does shut down because of no video input. i cant tell which output i'm on now i hit the wrong button and changed it from tuner. when the thing was on tuner it would stay up. there is no square board near the mainboard except the logic and it is brand new, and tested in another set.in the morning the y and z and power supply will be too, i am afraid to try the main in a working tv i do not own. the tuner section plugs into the main. the va and vs will not come up on this set but it is not like a short it is simply not getting the needed 5.1 volts thru the logic or main. the short is somewhere on the main i think. i would hate to spend 150 on a main and still not be the problem.Comment
Remember, not backlights but whole plasma panel. The boards that power up the panel won`t fire up the panel if there is a fault.
Backlights are what lcd panels use to backlight the lcd screen.
Since you have audio I think you are close to a repair since these tvs normally are just dead or go into protect mode right away.Comment
I ran into a little problem here with my 715t2454-2 board, T904 (the small vertical transformer) looking from the backside of the board on the bottom side with the 6 pins the third one in from the left side lost its connection surface on the board so it cannot be soldered on, can anybody tell me what i am missing in the schematics? the board was a chirper so i replaced the 3 caps and the 1 the q901 and d927 because it sounded like the chirp was coming from there but turns out it was the transformer so when i removed the old solder to give it a fresh connection the doughnut came off..... and help would be appreciated i would like to jump the lead and get the little bugger going
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Aspire Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office 365, Windows 10, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office 365, Windows 10, Silver) boardview and Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office...09-07-2024, 01:00 AM
- Loading...
