Re: toshiba regza no picture
I'm not sure they are fusible links as you would only have a few of them on the board and only near PSU inputs and things like USB... ???
Do you mean cant download from ET or cant get them to run. If the former have you remembered to disable any adblockers.Leave a comment:
"BTW those FL dsignations are Fusible links ,the board is covered with them"
That was actually what I was thinking they might be but was hoping they were
not. There are enough fuses: pico, glass ,ceramic, fusible resistors and the like
without having something else to check. I couldnt however find anywhere what the FL designation was - googled for over an hour. Do you know at what sort of
levels they pop.
Edit - Thanks for the Zeus linkLeave a comment:
levels they pop.
Hi guys my first belated post here !
Crt TV tech in my younger days .
Any thing electronic tech now !
I have one of these on the bench at the mo,but the 37AV555
Same boards etc
PSU board no SRV2169WW
Main AV board PE0630
Mine has a stuck in standby fault (due to the micro not sending a power TV
sig back to the PSU)AC det, 5V OK,Power on to PSU ok ,but the second TV on signal from the micro ...no go ?
With the PSU disconected it can be forced to fire up the 24v high current
rail ...so it appears its not the PSU,as all rails are present 5v-12v-18v-24v
Anyway not to hijack the thread , I have the schematics and the toshiba
Zeus app (to open the service manual )
Links
Service Manual (just AV board )The PSU and Inverter are 3rd party
http://elektrotanya.com/toshiba_32av.../download.html
And the zeus app for opening it,
http://elektrotanya.com/toshiba_zeus.../download.html
I would check all those for OC...Especially around the micro area.
Anyway ordered another AV board to continue my quest as i have spent hours with probes in hand and am convinced of a micro fault on mine,
We shall see,and will post back my findings.
Shall be watching this thread for any developments
Regards
PaulLeave a comment:
there is one at x1301 a metal box near the hdmi socket.
Question chaps In pic 4 post 13 bottom right corner there is a component FL981
wasted an hour this pm looking for the wiki list of component designations and when I found it FL isnt on. Any idea what it is?Leave a comment:
One potential cause of this problem is a damaged crystal oscillator - unfortunately, you would need a scope to determine this.Leave a comment:
thx anyways guys
Jamicon are "okay" caps. I wouldn't trust them on the output side of an SMPS, but they are okay for general purpose use as they are probably used in this case.Leave a comment:
That is normal for an autoranging meter. Assuming those regulators contain "33" in their part #, they are fine.
Are there any other regulators? Like these:
http://www.ictradenet.com/models_pic...PAK,TO-252.jpg
http://upload.wikimedia.org/wikipedi...4/4f/D2PAK.JPG
http://www.national.com/images/pkg/mp04a.jpg
http://media.digikey.com/photos/Rohm...B1132T100R.JPG
Anything you see that looks like those could be a regulator, so note down the part # and test the pins.
There is 1 jamicon 25v 1000uf on this board are they crap capsLast edited by sienoki; 04-10-2012, 07:01 AM.Leave a comment:
The Fluke 77, built before you were born, is only (by today's standard) 2.5 second display update speed and 3200 count multimeter. Modern Flukes are now 4 second display update speed and 6000 count.
Since both readings, 3.27 and 3.28, are beyond the Fluke 77's first range (likely 3.2V) this causes it to display 0L. The Fluke 77 then moves or autoranges to the next highest range (likely 32V) and finally displays 3.27.
Your BK 2709 is a 6600 count multimeter and would display the readings without the 0L.
edit: Too slow typing. You already knew the answer.Leave a comment:
Anything you see that looks like those could be a regulator, so note down the part # and test the pins.Leave a comment:
by jord4231Hi Everyone,
I'm working on a Toshiba 37AV500A Regza TV.
The issue:
TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
I checked the PSU voltages and everything looked good.
No bulging caps or signs of heat.
24v aud = 24.41v
12v = 11.98v
5v = 5.062
p_o/f = Goes high... -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
