Haier 40" LCD HL40XP1
  • uberplasma
    • Oct 2011
    • 85
    Hi All
    another dump special, a Haier HL40XP1 LCD with a broken screen, other than that works fine, all inputs and functions are perfect. So I whip the back off and to my dismay there are absolutely no numbers stamped on the metal frame of the panel at all, no stickers or anything. Haier America wants $808 for a new LCD panel and can't seem to find anyone selling them anywhere.
    Anyone know of a seller or, even better, the equivalent panel model # because I hear they are mostly samsung parts anyways.
    Re: Haier 40" LCD HL40XP1
    Generally not worth it to replace an LCD, but who made the inverter? (CMO, LG, Darfon...) Could be a clue as to the panel manufacturer.
    • uberplasma
      • Oct 2011
      • 85
      hey tom66
      my bad, thank you for reminding me, sometimes i don't think about the obvious, and looking at a post of the beloved Philips PFL series, it struck me, and bingo!! on the road to getting the panel replaced for far less than the 8 hundred they want for a haier panel
      Thanks again
      • myjanjua
        • Dec 2012
        Re: Haier 40" LCD HL40XP1 no pic but sound only
        Hi
        I have a Haier HL40XP1 the TV starts and works well then within two minutes the LCD goes black but sound remains. I turn off the tv and start after 5 min same thing happens. Apparently, there are no bulged or leaky capacitors.
        Earlier, I was not on badcaps but Tom thanks for helping a bit through email. Any help is highly appreciated
        YJ
        • howardc64
          LG 49UJ6500 LCD panel lighter band that goes away
          by howardc64
          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
          02-19-2023, 12:13 AM
        • triplefour
          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
          by triplefour
          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
          tcon is built into mainboard.
          Only one cable goes to panel boards.
          there is a cable from one panel board to the other that links them.
          cost cutting measure that results in us having harder time to diagnose.
          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
          07-28-2022, 07:59 PM
        • Storyteller12
          QN55Q60R Service Menu Panel Help
          by Storyteller12
          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
          01-13-2024, 01:57 PM
        • maneatingmonkey
          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
          by maneatingmonkey
          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
          03-27-2024, 07:17 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
