LG 42PC1D - Worth fixing?
  • Sneakyget
    • Feb 2012
    Hi guys
    First off, apologies if this is posted in the wrong area!
    I have a LG plasma with an issue with the power supply board, a few caps have blown. Before I think about replacing the set, is it worth considering a repair? And if so roughly how much is a reasonable amount to spend on this?
    Cheers in advance
    Jase
    Re: LG 42PC1D - Worth fixing?
    Does it click on and off repeatedly? Any sign of flickering on the screen?
    Replace the capacitors but report back when it doesn't work, as there is one last thing left to do, which is to disable the AC detect feature which causes a lot of problems with this particular model.
    The caps will cost less than £10. I bought mine here: http://www.thecapking.com
    • PSYKOCONNELL
      • Jun 2015
      I have one of these plasma beasts. I got it for free, with no remote or power cord. I found a compatable power cord and plugged it in. Without touching anything, there was a click, the white LED at bottom center blinked a few times, then another click and the LED was red. This all took place within 3-4 seconds. That's all the TV will do. I pulled the back cover off (I waited long enough for the caps to discharge) and examined the boards. All the capacitors look fine, none are bulged indicating a rupture. I checked all the fuses on the boards with my multimeter, found one bad fuse on the X board I believe, the board on the right side when looking at the back. I've done some researching online and a majority of the "how to" vids on youtube and links are about changing the caps.
      So, this is a 42 inch plasma TV that so far has cost me nothing, would be a nice TV to have, is it worth time/effort to troubleshoot further and see what it needs to make it work? What do you guys think?
      For the record, it's an LG 42PC1DA-UB, date of manufacture 2006....
      I appreciate any tips and help guys, thank you!
      • iamwise
        Asus TUF Gaming F15? Is this worth fixing? PCH WARM
        by iamwise
        Hi all, I picked up a liquid damaged Asus TUF Gaming F15, does not power on, model FX506HM-HN004T.
        Ive gone as far as removing the case and doing a visual check, there is no visible corrision, upon plugging in the power brick a single led light shows that power is plugged in, but no display or fans, the PCH chipset gets warm/hot to the touch, could this mean its not fixable or do I proceed and remove the motherboard completely and check further for shorts etc, failing that should I just take it to a service centre and go from there
        what would you do? my skillset is...
        08-03-2022, 05:06 AM
      • r-p
        Maldischarge-link that fixes it with replacing caps
        by r-p
        Starting this thread because Capkid doesn't seem to be reprogramming controlboards anymore (LG 60PZ950 with red maldischarge) and my game-plasma also has maldischarge (Hitachi 42PD3200). So I will grasp at straws to keep them running. I am extremely bad at throwing stuff away.
        Is there any merit to this link?
        Very short version: Specific caps seem to loose their capacitance and/or increase their ESR. This may cause the maldischarge. Replace them with better/bigger/newer ones and problem solved.
        From the limited knowledge I have on the subject, I think...
        01-21-2020, 05:16 PM
      • ArMaaN376
        Samsung PS51E550 Plasma TV
        by ArMaaN376
        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
        Opened TV cover & observed foll
        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
        How to confirm Y -Buffer board...
        06-19-2024, 04:05 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • KYBOSH
        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
        by KYBOSH
        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
        No picture but you hear the TV static (white noise) playing loud and clear.
        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
        But it seems they didn't get too far and just left it.
        When I first took a look I was amazed at how pristine the inside looked.
        Its as if the TV had been in a time capsule.
        Caps looked like they were just pulled off the self.
        Copper coils had no sign of corrosion on...
        02-01-2023, 11:10 PM
