RCA L42WD22 Failed Update
  • PizzaG
    • Jan 2012
    hey guys first post. quick rundown is got it for 100 on craigslist with apparent backlight issues. after some testing with multimeter found it was inverter board. so 60 on that and it worked awesome for 6 months. i thought it would be smart to update it since one was available. followed instructions and the update failed halfway through. upon restart there is now only black screen and green light. Any known way to reflash the update, a recovery menu that will save me, or anything i can do other than get a whole new mainboard for 130? the upgrade menu no longer comes up. and if i do have to replace the board, is the flash chip located on the a/v mainboard? i figure the tv is still worth fixing with about 300 total in it and 6 months use. great tv when its working
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • ahmedtou
    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
    by ahmedtou
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next
    08-27-2025, 08:49 AM
  • test.it
    Failed bios update on a Dell Precision 3650 Tower
    by test.it
    Can anyone help me with a failed bios update on a Dell Precision 3650 Tower, service tag G01WWM3. The reason for the error was a power failure during the update. System no longer boots, no POST....
    01-28-2025, 07:32 PM
  • Yacine007
    HP victus 16 update bios failed
    by Yacine007
    hello dear friends
    I recently bought this motherboard and I'm having a lot of problems.
    - The Wi-Fi doesn't appear in the Network Card in Device Manager (The Wi-Fi card and the Wi-Fi work fine when I installed the old motherboard)
    - The hard drive is missing when i reboot the system and reappears when i reboot again (crtl+alt+del).
    - When I tried to do an internal BIOS update it doesn't work it always fails.
    Can someone help me update the BIOS or give me a new clean BIOS?
    hp Victus 16-e0xxx
    SN 5CD2050PSQ
    Thank you in advance...
    09-28-2025, 05:30 AM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
