Re: A guide to fixing/troubleshooting some common plasma TV problems
Since they are vertical, it is most likely the plasma panel data drive ICs. These are not replaceable. However, if they are moving, it could be the control board or distribution board.
Do you have any suggestions for a problem I have with my old 42" plasma TV which is an NEC PX-42VP4G/S. The symptoms are thin vertical lines which seem to move occasionally and vary in colour. Other than these lines the display is fine but they are obviously distracting. I took the TV to a local electronic service shop and they say that because the lines are spread the entire width it can't be the Y-Driver but is most likely the chemically bonded connections to the screen itself which can't be fixed and would cost about £1000 to replace the screen. Does your guide referring to horizontal lines apply to vertical lines that I have? As you can tell I'm pretty stubborn with fixing things and like you I hate scrapping this sort of thing unless I am convinced there is no other option. Any advice would be greatly appreciated!
