Toshiba Regza 57Z3030D dark patch on screen when cold
  • TrustyBear
    • Oct 2011
    • 5
    I have a Toshiba Regza 57Z3030D, when cold, there is a dark patch down the centre of the screen, not blank, but darker than the outer edges.
    As the set warms up, (about 30 mins) the screen flickers, and the image becomes perfect.
    I have checked the psu outputs and they all seem within tolerances.
    where to look next, inverter, ccf tubes, main logic?
    Has anyone any experience on large Toshibas who could guide me the right way?
    Re: Toshiba Regza 57Z3030D dark patch on screen when cold
    This is a classic case of bad tab bonds. It's sometimes, but not always fixable. The LCD panel is faulty and this is a very expensive part.
    http://www.youtube.com/watch?v=zW998RTAq-0
    http://www.youtube.com/watch?v=vCExlSnG4yY
    The same problem manifests itself in different ways. Sometimes you can get dark patches which warm up and the TV behaves fine. Other times, one side is permanently slow to change and does not work properly.
    A simple way to verify the diagnosis is to apply a little pressure to the top of the TV and see if the picture fixes itself.
    • TrustyBear
      • Oct 2011
      • 5
      Thanks for that, it looks like that could well be the problem.
      I will post back when I have tested the tabs.
      • TrustyBear
        • Oct 2011
        • 5
        Just a thought, but could a Philips 32PFL5522D/05 that shows a red screen when cold, and comes right after about 30 minutes be the same thing?
          Quite possibly. I had a Philips TV with a similar problem to your Toshiba but not that bad, as it cleared itself after about 2-3 seconds.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
            09-06-2024, 05:27 AM
          • sigmeyer
            Toshiba 50UL4B63DG faulty screen?
            by sigmeyer
            I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
            08-30-2025, 08:13 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
            09-06-2024, 05:59 AM
