Samsung PN43D450A2 Has No Remote, What to do?
  • Paul678
    • Nov 2011
    • 402
    Got this free one with a cracked screen. It's hard
    to tell, but it's possible only the covering glass is cracked,
    and the panel itself may be ok. Story is, the person
    won the TV, got it delivered, and it was cracked
    during shipping. They delivered another one, and
    she gave this one to me.
    At any rate, the original owners didn't have the
    remote control, and amazingly, in what must be
    one of the stupidest engineering decisions ever,
    there is no power switch on the edge of the TV
    itself! Unheard of! My only guess is that they
    were desperate to shrink the size of the TV, and
    got rid of the manual controls in the process.
    But what the hell do you do when you don't have
    the #$@#*% remote?
    Anyhow, when I plug it in, a relay clicks, an LED
    on the logic main blinks 3 times, and there
    is a somewhat disturbing buzzing noise, and then
    another relay click, before it settles down, so there
    is obviously standby voltage.
    The caps seemed ok, but as everyone knows, you can't
    tell by looking....but there were no obvious signs of anything
    burned out.
    In the second photo, I measured PS_ON to be +3.3V, and
    STBY to be +5.33. There were no other voltages present
    (i.e., no Vs, etc.),
    I've read on the other threads of using batteries to turn
    on the board, can this be done with this tv? Or does PS_ON
    have to be 0 volts for the PS to turn on? Or can you
    fool the board into thinking there was an IR sensor signal
    for turning the set "ON", with the connector in the extreme
    lower right corner of the first photo?
    If I'm amazingly lucky, the set will turn on, and the plasma
    panel will still be good, and I'll just need a new glass covering.
    But much more likely is that only the boards work. But I still need
    to at least verify the voltages are present, before I post these
    to Ebay......
    Thanks in advance......
  • Paul678
    • Nov 2011
    • 402
    Re: Samsung PN43D450A2 Has No Remote, What to do?
    Ok, the plasma panel popped out, and unlike my
    other Magnavox, there isn't any protective glass
    over the panel, so the panel itself is cracked,
    and therefore toast.
    But I'd still like to verify the voltages on the boards.....
    • Paul678
      • Nov 2011
      • 402
      Opps! Nevermind! The manual controls are
      super hidden, and are almost invisible from a distance!
      Ok, it turns on, and there is actually a "windows"-like
      welcome sound from the speakers. But there is also a loud
      annoying buzzing sound, somewhat like a a very high pitched
      motorboat, loudest in the lower right hand corner of the first
      picture I posted. This buzzing stops when I disconnect what
      appears to be the Ysustain board on this unit (the tan
      board on the left in first pic). I suppose this buzzing
      is due to the cracked plasma panel?
      But the Vs, Va, Ve voltages are all good (only present
      with Ysus connected, so turns off in no-load condition),
      and the others appear good as well.
      It looks like the boards are probably good in this case.
      EBAY TIME!!!! LOL!!!
        09-07-2024, 05:50 AM
      • jesterace
        Samsung B2030HD IR Remote Receiver Dead, shorted micom?
        by jesterace
        I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
        Tried installing latest firmware but no change.
        TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
        Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
        10-26-2022, 02:20 AM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
