Hello everynone , greetings ! I am back with some more questions in reference to this model . The tv would not power on , have a red light on , there is a noise coming from a transformer or coil when attemting to power up , then it quiets down but nothing happens . I have checked just about every component including the large filter cap 450 volts 820uf 4 pin capacitor in and out of circuit , ( it reads 745 uf ) I believe there is a 20% margin which is cutting it close. When I checked the voltage across this cap ( is 158 volts DC ) but the second I disconect the power it goes down to no or zero voltage ) My question is :1) Is these cap shorted or leaking and could this be the reason or one of the reasons preventing the tv to come on ? 2) I have two in rush current protection thermistors rated at NTC 4,7 that were questionable when I first saw the board , one of them was kind of charred and seem to have suffer from overheating , the solder was dry . I resolder them back . When measured with the ohmmeter I get 2 ohms reading at room temperature ,is these a normal reading? Am I supposed to read more ohms (NTC 4,7) or are they too low for what they should be ? What is the equivalent for 4,7 .if anyone could help please . Also another weird thing happen while checking dc voltages across a resistor , meter started to read dc voltages , frequency in Megahertz . I didn't know my meter could put frequenzy numbers on the display , any one have an explanation for this phenomenum, thanks for your time and advise ,any help is appreciated . Thanks , BB333
Apex GB5108 Chassis PU 1 rear projection tv
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD,...09-07-2024, 03:10 AM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...09-07-2024, 03:10 AM
by waigyAs the title.
I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
It looks basic enough inside with large components so I could do a full recap pretty easily.
Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
I thought I had dodgy speakers as I just fitted new old stock 6x9s in...17 Photos-
Samsung LED LCD TV Chassis U57E U57F U56G Schematic
Chassis: U57E
Model : UE40D500*BW
UE26D400*BW
UE32D400*BW
Chassis: U57F
Model : UE22D500*BW
UE19D400*BW
Chassis: U56G
LE32D400E1W
LE32D40*E2W
LE40D50*F7W
UE26D4003...-
Channel: Schematics and Boardviews
11-05-2024, 04:00 AM -
by howardc64TV was fixed just after removing Samsung's rear snap cover.
This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
Maybe PSU->backlight connector didn't have a good contact?... - Loading...
