50" LG Plasma poor image
  • fusionlore
    • Sep 2011
    • 12
    I have a dark screen that lightens up after TV has been on for a short time. See pictures. The black will fade as the image changes though slower than the picture does. I replaced three boards 2 weeks ago, I believe they were the z-sus, y-sus and the board they are attached to. Sorry trying to do this quickly during lunch so. Any help would be appreciated.
  • rayrod81
    • Oct 2010
    • 205
    Re: 50" LG Plasma poor image
    The symptoms you have described and show in your pictures are usually related to a failed Z-sustain.
    • fusionlore
      • Sep 2011
      • 12
      Thanks, I replaced the z-sus already and all was fine for a couple weeks so probably got a bad board.
      • fusionlore
        • Sep 2011
        • 12
        Anyone know where to download pictures that would identify the internals of this tv? I'm not sure which one is the zsus.
        • bbjunkie
          • Dec 2011
          • 301
          Hi fusionlore - Take a picture with the back off. The guys here will be able to tell you.
          Jim
          • PlainBill
            • Feb 2009
            • 7034
            When viewing the TV from behind the Z-sustain is the one on the right.
            PalinBill
              Could also be a loose Z-sus power or Z-sus control connector.
              • fusionlore
                • Sep 2011
                • 12
                Thanks, I will take pictures tonight.
                • fusionlore
                  • Sep 2011
                  • 12
                  Here is the pic. Arrows point to the 3 boards I replaced. When I got the TV it had sound but no picture. After replacing these it was perfect for 2 weeks then a new problem arose as seen in the photos at the beginning of this post. Thanks for any help.
                  • pwogaman
                    • Dec 2011
                    • 3
                    Those arrows point to the y-sustain and the buffers. The z-sustain is on the other side.
                      Replace the Z-sustain. Before you do this, check the fuses, and replace any that are blown; if they blow again or the TV doesn't start, replace the Z-sustain.
                      • fusionlore
                        • Sep 2011
                        • 12
                        Thanks. Both fuses tested good and the unit does power on but the picture is poor as seen above. Does this still indicate the Z-sustain?
                          Yes the Z-sustain can also fail open. Try disconnecting the Z-sustain driver FFCs (connectors to panel) - does the picture change? (Do this while off, of course - dangerous voltages present.)
                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-12-2024, 02:20 PM
                          • Jaime Morillo
                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                            by Jaime Morillo
                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                            The TV was stuck on the logo and I couldn't access the update menu.
                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                            The image result was good, but the image is inverted.
                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                            08-18-2025, 11:38 AM
                          • piershs
                            Toshiba plasma 50WP16 wierd double image fault
                            by piershs
                            My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                            Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                            • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                            • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                            08-01-2020, 01:07 PM
                          • Delired73
                            TV LG 50PA4500 Plasma : bad image noisy
                            by Delired73
                            I have an issue and didn't find any solution by myself or on every forum about my LG plasma TV 50PA4500.
                            Originaly the TV stopped to work and didn't want to turn ON again.
                            After visual inspection, few transistors were broken, I tried to change them but some burned again, so I ordered on full new board. So, I changed the Yboard which was burned by a new one
                            It now turns ON and the image and sound are present. But the image is very noisy and only visible when the room is in the dark.
                            I check Vs and Va voltages...
                            04-04-2021, 09:13 AM
                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                            09-06-2024, 10:56 AM
