Need Help Finding Caps
  • knoxrebel
    • Oct 2009
    • 168
    i have a tv that needs some new caps for the power board. Badcaps is out of the 3300uf at 10 & 16v and wont restock for a while. Where can i get these? I have checked digikey and found a huge list, but im not sure what product series i need to be looking at for each manufacturer.
    Thanks in advance.
    EDIT : I need two 3300 @ 10v (10mm X25)
    two 2200 @ 10v (10mm X 25)
    four 680 @ 35v (10mm X 25)
    Im looking at these part numbers
    EEU-FR1V681L
    EEU-FR1C222
    EEU-FR1A332
  • PlainBill
    • Feb 2009
    • 7034
    Re: Need Help Finding Caps
    Thanks in advance.
    EEU-FR1V681L
    EEU-FR1C222
    EEU-FR1A332
    I don't know why you are asking for help, you seem to have done very well on your own. Those should be excellent replacements. I note that you have selected a 2200uF, 16V cap, not a 10 volt as you mentioned above.
    If you are seeking validation for your efforts, here it is "You did very well".
    PlainBill
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • fl0w
      GeForce 6800GT recap, need help identifying caps and finding replacements
      by fl0w
      I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
      But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
      I need to replace:
      • 2x 2.5V 1500µF => I plan to use this
      • 2x 16V 330µF=> I plan to use this
      • 1x 6.3V 680µF=> I plan to use this
      Am I correct with the cap choices?
      Thanks for...
      10-02-2024, 11:28 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
