Seeltech ST2468DHD 24" LCD HD TV Standby only - help needed!
  • joste
    replied
    Re: Seeltech ST2468DHD 24" LCD HD TV Standby only - help needed!
    Thanks, Tom!
    Well, I agree with you regarding caps, and it also has crossed my mind to search for these voltage regulators on mainboard. The biggest one (first one on the far left corner of the mainboard) is BM1084, probably giving supply voltage (5V) to CPU or even USB port. I was about to test them all, but I need to have a snack first, I'm starving :p
    I'll be back with readings asap, thanks!
    replied
    Jamicon are okay - the set should power up with them. But it will probably die in a year or so using those. Regardless, I don't think those are the main problem.
    It's pretty common to see the main processor having a heatsink. That chip integrates a CPU, video scaler, and audio decoder all-in-one to reduce the cost. Probably also has a DVD player decoder for the DVD models.
    I've highlighted what I think are some voltage regulators. Using a digital voltmeter, measure the voltage at all three exposed pins and the metal tab for every one and report back. If one pin doesn't connect to the board (like with the big regulator, bottom left), no need to measure it. Also, report back the model number on the chip, it will be something like "AM1117-33", for a 3.3V regulator of the AM1117 series. To measure, use the red positive lead to probe a pin, and connect the black lead to the metal case of the TV, or the back of the LCD panel itself.
    Also, could you take a higher resolution picture of that board? I'm struggling to read the component IDs (U9, R82 etc.) on it.
  • joste
    replied
    Power/Invertor board producer is AOUYAN, model LP220401 REV1.8. and so far I haven't found anything on it, except for one single forum in Italian where people have had the same board in some other Sansui TV set, but there the problem was clearly burnt active semiconductors (MOSFET and the rest) and after all they used an external 12V PSU to power up the set as invertor worked well with it.
    Capacitors used were really Jamicon 1000uF/25V 105°C and I have used them to repair other sets (mostly Samsungs) and it worked well, so I don't see why they wouldn't work here as well?
    I'll try to be stubborn again and make it power on again, measuring stability of these 12V and what happens with pin ON/OFF.
    The mainboard is some CV209L, no hits at all. the board has many unused connectors for a DVD player as an option (for other models). I don't find anything else to be so significant about it. And yes, the CPU is covered with an aluminum cooler, so I don't know what it is. All I know is that it used to work very, very well until two days ago and then - poof!
    Thanks again Tom66, please let me know your thoughts.
    replied
    Originally posted by joste
    @Tom66,
    Thanks for your reply. Here are the pics, and I can tell you that I've tested all diodes (even SMD ones) and they seem to be OK, even Schottky. I even managed to turn it ON once (just by being stubborn), but it lasted for 30 sec and TV went to Sdby all by itself. Since then, no luck at all. The whole Power/invertor board has been properly recapped, still the same.
    Yes, you'll notice just two 12V rails, one ON/OFF and one ADJ. The rest is GND.
    So, the set is always in Standby, no way to make it turn ON.
    I feel it's some dumb thing, but I can't find it and it is driving me a bit crazy (the TV is my only 1080p TV screen).
    Let me know if you'd need any additional info, I'll be glad to provide it asap.
    Thanks and looking forward to your thoughts.
    That's odd. It appears that there is no standby bus in the TV, am I correct? So I think we can rule out the power supply itself as being at fault. Can you attach a picture of the main board?
    Then again, I see the ON/OFF pin. Perhaps this is only for the backlight...
    Are there any part numbers on the power supply board which might be helpful in tracking down a service manual? e.g. on one power supply I have here there is a sticker saying "DPS-182BPB", which brings up hits for Philips 32" TVs. (Which is correct.)
    Which capacitor brand and series did you use to do the recap? They look like Jamicon, which are general purpose capacitors and these will probably not work so well.
    As you were able to get it to turn on once, see if you can do that again, and measure the power supply rails: if they are too low then the TV could be shutting down because of this.
  • joste
    replied
    @Tom66,
    replied
    Can you photograph the top and bottom of the board around the connector which goes to the main input board? From this position it looks like it only has one or maybe two power supply rails; this will make it easier.
  • joste
    replied
    No ideas?
  • Seeltech ST2468DHD 24" LCD HD TV Standby only - help needed!
    Hello all!
    Yesterday my Seeltech ST2468DHD 24" LCD HD TV has stopped working. It was on and after few minutes it went to Standby all by itself, then two seconds later came on again. It didn't take too long to repeat this and then I decided to stop it, unplugged power cord, waited a bit and plugged it back again. But, this time TV didn't want to turn on, it was constantly in Standby mode with red LED on.
    I have changed all electrolytic caps on its Power/Invertor board (producer is AOUYAN, model LP220401 REV1.8.) but it didn't make any change. I still have stable 12.08V voltage and red LED on. The set doesn't respond neither to IR remote, nor to its keys.
    So, I wonder if you guys would have any advice on this, I will appreciate it very much. If you'd need more details, please let me know. For now, I'll hang on the photo of the power/invertor board, maybe it'll bring some memories back.
    Thanks!
  • mecha1166
    QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
    by mecha1166
    I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
    03-28-2024, 08:31 AM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • Crystaleyes
    Samsung BN44-00259A standby question
    by Crystaleyes
    Hi all.
    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
    08-11-2023, 05:15 AM
  • psssst
    Yamaha TSX 120 Standby Problem
    by psssst
    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
    03-01-2024, 07:25 AM
