Seeltech ST2468DHD 24" LCD HD TV Standby only - help needed!
  • joste
    • Aug 2011
    • 42
    #41
    Re: Seeltech ST2468DHD 24" LCD HD TV Standby only - help needed!
    To be honest with you, I'd sell the whole set for a hundred quids. There's a small superficial scratch on the lower lefthand part of the panel, but you can't even notice it once the screen goes on.
    I know you're not interested, I wrote this for other folks who might be reading this thread.
    I'll post panel reference later, and power supply/invertor board is still in mint condition!
    Not to forget IR RC , still with original batteries!
    • joste
      • Aug 2011
      • 42
      #42
      Good news! The set has been successfully repaired!
      I had a telephone conversation with a tech from the company that is official importer and wholeseller of this brand and he was very kind to share his knowledge and experience. He said that this failure is very common for this model and that in more than 60% of all cases it is the diodes around the coils on the left hand side (SMPS). These two 1N4001 have been looking good both in Standby mode and disconnected. But, the catch was in what happens once the current hits them. So, I followed his advice and changed the diodes with 1N4007C. Once my soldering iron was hot, I took the oportunity to change their 470uF/16V caps just in case.
      The result was as follows:
      - TV turns on quicker than before
      - FLV media files are displayed without any problem, which wasn't the case before the repair. In fact, the set finally broke while I was playing the same FLV file. It is possible that CPU requires more current to decompress certain contents and that was the moment when the diodes (and possibly caps) finally failed.
      I have also found the exchange mainboard, but its price of 140€ (VAT and shipping included) but luckily I didn't need it.
      So, guys, thank you for reading this and thanks for the help you provided.
      See you soon on the forum
      Cheers!
        Cheers!
        Wow, failed diode? I thought you checked those. Anyway, enjoy your fixed TV! I guess talking to the company actually worked. Wow.
        • joste
          • Aug 2011
          • 42
          #44
          Hi Tom66,
          Yes, you're right, all diodes where checked and they measured OK. But, once the current hits hard (on startup), they kinda "change their mind". Who knows, maybe the caps (also looking good, no leak, not bulged) have lost a lot of their capacity, so the switch couldn't give current needed to power up the CPU.
          Whatever, I just can't take my eyes off the screen. I've missed my TV so much and I really am happy to have it back.
          Yes, talking to people can often help much. That's why I appreciate this forum and your help.
          Thanks again to all of you guys and certainly you, Tom66
          • jacouille
            • Nov 2013
            • bretagne
            #45
            bjr, I have a lcd seeltech 2468 with the same failure can say vs el component that I need to change the map to repair this tv seeltech
            thank you very much
            I am in France
            • j2c2grabels
              • Aug 2014
              • France
              #46
              My peekTON 15.6" TV have the same mB and almost the same problem. I replced the 2 1N4001 that seem to be good (testing diode function of my old Fluke 77 multimeter) and my TV is runnig OK again !
              Thank you very much for your explanations.
              • vaneno
                • Oct 2011
                • 7
                #47
                Hello. Sorry for revive topic. Yesterday i fix another tv with same faill. Mine was a blusens , 22", same MB. It was remaining allways on stand-by. After reading this, im going directly for 1n4001 and 3 caps 470uF, and fix it on half hour . So, many many many thaks for share.
                • joste
                  • Aug 2011
                  • 42
                  #48
                  Hi vaneno,
                  Thanks, it is always a pleasure to see someone was able to use our inputs successfully.
                  Regards,
                  Joste
                  • mecha1166
                    QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                    by mecha1166
                    I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                    03-28-2024, 08:31 AM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
                  • psssst
                    Yamaha TSX 120 Standby Problem
                    by psssst
                    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                    03-01-2024, 07:25 AM
