Beginner trying to fix LCD
  • johnyzee
    • May 2011
    • 6
    Our LCD tv stopped working. It was giving a humming/buzzing sound for a couple of weeks, sometimes blacking out the screen (at which point the buzzing noise would stop, but sound in speakers still playing). Now the screen is totally black, still a faint buzzing sound.
    From what I've read this indicates a failure of the inverter board. So I have taken the thing apart and I think I have managed to locate the inverter board (see attached image). I have looked it over for anything obvious, the only thing I notice is a burnt looking area at one of the capacitor pins (see image).
    I was hoping someone here could give a look and let me know if (a) I am correct in assuming this probably a problem with the inverter board, and (b) if the capacitor shown looks faulty to you? I know from browsing that a capacitor can be bad even without visible signs, but I will only proceed if I am sure that I have located the (or at least one) obvious problem.
    The TV is a four year old Philips 9632D (42"). I got most of my inspiration from this thread describing a similar problem (same model TV, same inverter board): https://www.badcaps.net/forum/showthread.php?t=14128.
    Thanks in advance for any pointers!
  • johnyzee
    • May 2011
    • 6
    Re: Beginner trying to fix LCD
    Just to get ahead of myself a little bit, if the capacitor is indeed bad, can that in itself cause the buzzing sound I've been hearing, or does that indicate an additional problem? It would surprise me that such a small part would make that much noise, and also it sounded more to me like the sound was coming from the power supply board but I may be imagining things?
    Can I replace that capacitor with a simple soldering iron and some tin (never soldered anything in my life)? Is the capacitor a widely available part or would it need ordering? I have a well stocked electronics boutique near here. Also, will the part itself be enough to get the replacement, or do I need a schematic to determine which part to get?
    • retiredcaps
      • Apr 2010
      • 9271
      1) If you have a multimeter, check the fuse on the inverter board (right underneath your green circle). A good fuse should measure less than 1.0 ohms.
      2) The brown stuff on the cap looks like leftover flux residue from the soldering process. You can verify by trying to remove the flux with a q-tip and some isopropyl alcohol.
      3) When the screen goes black, does the power indicator LED stay green?
      --- begin sig file ---
      --- end sig file ---
      • johnyzee
        • May 2011
        • 6
        1: I don't have a multimeter (don't even have a soldering iron yet). Is the fuse the white thing with metal at each end that says (...)12A? As you can tell I am starting from zero, so I am praying for something blindingly obvious that even I can deal with .
        2: Will try, you're probably right. On closer inspection the other pins have a little bit of residue too.
        3: The light stays green (blue actually).
        • retiredcaps
          • Apr 2010
          • 9271
          Yes.
          • johnyzee
            • May 2011
            • 6
            I attached a picture of the power supply board, and a picture of the entire backside for reference - the inverter board came off at the very right by the metal next to the TV.
            I don't see any obvious problems on the power supply board.
            Do you think it would be worth trying to fix the thing (taking into account my limited experience with electronics repair)? Is replacing one or both of these boards likely to fix the problem in your opinion, or are there other easy steps I can take to troubleshoot further?
            I would hate to throw away a fine TV if a couple of cheap parts would fix it right up.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • valente222
              LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
              by valente222
              Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
              11-18-2024, 03:21 PM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:30 PM
