Protronics PLTV-3250
  • slammed87d21
    • May 2011
    Ok, I got this tv in non-working condition and finally decided to fix it since my Ilo CRT tv's vertical output is failing and I'd rather have a flatscreen.
    Anyway, here's what it's doing. As found, nothing at all. As per a thread here, and elsewhere on the web, I read that a transistor and zener needed replaced to get output voltages from the power supply.
    So, I replaced the transistor (Q7 I believe) and the zener. Nothing from the output still. Figured I would re-seat all the cables in the tv, and try again. After re-seating all the cables, the standby light came on. Hitting the power button, it turned green, and the light ould flash with the pressing of channels or volume. But no picture. Not like the lights were off, but the screen had power. Using a flashlight, there was no image on the screen.
    My electronics knowledge is with vacuum tube electronics, but I have done some repairs to newer electronics, so I'm not a total noob. So anyway, here are some pics of the power supply, and the components I replaced. When you see my work, keep in mind I work on circuits that don't have circuit boards normally.
    PCB Top by Tubes2Transistors, on Flickr
    PCB Bottom by Tubes2Transistors, on Flickr
    new transistor and zener by Tubes2Transistors, on Flickr
    After replacing the transistor and zener, I saw this.
    darkened pcb under transistor by Tubes2Transistors, on Flickr
    Under neath that transistor, I found another bad Zener.
    zener under darkened pcb by Tubes2Transistors, on Flickr
    Any suggestions on where to go from here?
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
  • nev1001
    What zener diode might fix the sound on Maestro Mayhem gaming chair?
    by nev1001
    Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
    The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
    It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
    I think an issue could be a zener diode (or capacitor) which has shorted out.
    The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
    04-17-2025, 05:09 PM
    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
    I bought this from an eBay seller but unfortunately they only had one
    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
    I bought three of from them to also make battery packs with this output power limit in mind
    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
    04-23-2025, 05:50 AM
  • unimatrix93
    TV backlight zener diode
    by unimatrix93
    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
    The led strips has 9 6V leds.
    02-10-2025, 12:13 PM
  • Vincenzo2
    Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
    by Vincenzo2
    My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
    Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
    I put some pictures here to show that it is labeled "M7"....
    09-07-2023, 07:43 PM
