Sony bravia kdl-46s4100 lcd problem need advice
  • sunnatullo
    • Feb 2011
    My KDL-46s4100 TV is out of warranty. I had dark line on the bottom side of my TV, also it had picture delay on left corner.
    Now I have no pictures, only sound. Could someone tell me what part is bad, so I can replace it by myself?
    Thank you
    Here is my video on youtube showing my problem:
    http://www.youtube.com/watch?v=7pJteewNiW4
  • JUCaESAl
    Sony bravia KD-65AF9
    by JUCaESAl
    Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
    Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
    10-20-2025, 04:03 AM
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • alegatorul
    sony bravia kdl-43w756c, no power, no sound
    by alegatorul
    the charger brick has 19,2-19,3 vcc
    changed the inverter board same result.
    where should i start?
    cheers
    11-15-2025, 10:00 AM
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • justin35
    Sony bravia kdl-43w755c - boot loop
    by justin35
    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
    from what i read online it looks to be an emmc issue…
    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
    i took out the board and say an samsung 16gb emmc
    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
    i could try to put one instead of the 16gb one, but will it work?
    where do i get the software from?
    any help will be much appreciated!...
    03-06-2024, 12:26 PM
