Samsung 933HD not staying on help
  • alexanna
    • Mar 2010
    • 1346
    Re: Samsung 933HD not staying on help
    Originally posted by mots
    The readings changed when i plugged everything in and turned it on, they are as follows;
    1) B-Dim = 1.50
    2) +15v = 15.44
    3) GND
    4) GND
    5) GND
    6) +5.1v = 5.18
    6) +5.1v = 5.18
    7) A-Dim = 0.70
    8) On/Off = 5.02
    I have attached some pictures of the logic board, is there any way I can test the voltage regulators?
    Your pictures are to blurry to tell a lot.
    A voltage regulator should be identified by a “U” designation on the PCB.
    They should have 3 legs and a tab. or 2 legs and a stub in the center and a pad.
    If you are lucky they may have somewhere in the part number a 33, 25, or 18 those would indicate 3.3volts 2.5 volts and 1.8 volts
    The tab is the output voltageThe voltages that you just posted, was that with the monitor working? use the ground Dgtech sugested in an earlier post
    • mots
      • Jan 2011
      • 13
      There are loads of components which have "3 legs and a tab. or 2 legs and a stub in the center and a pad." but none have a "U"
      I will take another look at the board later and try and take some more detailed pictures of the board
      Is there a way to test each one of these components to see if any is failing?
      • alexanna
        • Mar 2010
        • 1346
        Yes better pictures would help.
        I am not the person to help you test these.
        The point I was trying to make is that I have seen voltage regulators do some strange things.
        I have noticed them starting out at an acceptable voltage and slowly over time noticing the voltage go low to point things stop working.
        Your problem may be difficult to solve because of the fact you sometimes having a working unit. And sometimes non working
        • mots
          • Jan 2011
          • 13
          Sorry for not replying for awile but I have got a new power board to test and was waiting for it to arrive - just set it up and it seems to be running fine for the moment so that means it is a fault with my old power board hmmm is it worth buying a new power board or better just to buy a new lcd?
          • mots
            • Jan 2011
            • 13
            ok after a few days its the same thing with the new power board
            Im just thinking do you think it could be the part in the tv which has to recognize which source is plugged in/ sending a signal to tv that is failing?
            Any help at all would be greatly appreciated again - is there anything more i can test?
            Thank you
            • freecom
              • Nov 2011
              • 18
              • greece
              #26
              same monitor tv.....problems like tv monitor before
              turn on very hardly after 5-6 times trying
              the best way to start is to warm the main board with hot air
              if turn on then all ok for many hours !
              probably the problem is in main board
              i test all caps with esr meter but nothing.....all caps good
              i resolder many items in main bord.....but nothing
              100 % same problem like me
              http://forums.cnet.com/7723-13973_10...-always-start/
              • freecom
                • Nov 2011
                • 18
                • greece
                #27
                my sam ok
                solution
                reflow with hot air + flux
                in main board.....procesor....flash memory....and other
                finaly all ok
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
