Samsung 42" SP-R4212 Plasma no video good audio
  • crang94
    • Jan 2011
    Hi. I am looking to repair a 42" Samsung plasma tv that has had intermittant problems up until now, which is now a permanent problem.
    Model: SP-R4212, Type: SR42S5
    Possible defects: Ysus (LJ41-03424) Ybuffer(LJ41-02249, LJ41-02248)
    Symptoms: No video, good audio. With bevel removed (exposed PDP) you can see white snow (very dim) occasionally while the set warms up. Completely dark after 60 seconds or so. The no video issue started intermittently: the set would go dark, then come back online, and off again. Sometimes it would stay dark for a few minutes, then other times never go bright again. The set is now permanently dark (but with audio).
    Resources: digital multimeter, 100 Mhz. scope, time and patience, empty wallet.
    Based on online forums and service manuals for a similar model, I think that the ysus board is toast. I can't tell for sure, and based on the components, I would think the board can be repaired. The buffer chips are all cold to the touch, and I see waveforms at the OUTL and OUTH test points, but I don't know if they are good.
    The voltages out of the SMPS are OK.
    I am looking for information on how to test the overload circuits, possibly a schematic for the Ysus board, or suggestions on which components fail on these boards. I can buy a rebuilt Ysus, but I don't know if that is the problem....
    Any suggestions ???
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 42" SP-R4212 Plasma no video good audio
    Any suggestions ???
    1) Patience -> required for some of these problems.
    2) Coppell TV repair blog might be useful. See below
    http://blog.coppelltvrepair.com/2010...according.html
    http://blog.coppelltvrepair.com/2010...-lines-in.html
    --- begin sig file ---
    --- end sig file ---
    • Judy
      I have a 60" Samsung tv plasma, that has very little color, picture is shadowy. Audio is fine. Can it be fixed.?
        Yes, it is the X-main board at fault.
        Please put help requests in a new thread created by yourself.
        • ainsworth
          • Oct 2013
          • 23
          • jamaica
          I have a Samsung Sp-r4212 with no display but I'm getting audio.
          I pulled it apart I saw a bad ic on the YB (up) board. Could this cause the problem?
          • ainsworth
            • Oct 2013
            • 23
            • jamaica
            This is a picture of the circuit board
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              That's a badly blown buffer IC so I would be concerned that there is a short circuit on the Plasma panel.
              Check the plasma panel very carefully to see if you have a crack in it.
              Others welcome to offer advice.
              • ainsworth
                • Oct 2013
                • 23
                • jamaica
                If I replace the board with the buffer ic's I should be able to get display again then?
                I haven't seen any cracks in the screen.
                • ainsworth
                  • Oct 2013
                  • 23
                  • jamaica
                  I replaced the Y Main YSUS board but still no display
                    09-07-2024, 05:50 AM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
