Unfortunately, I would not know where to source them from. You could contact a company that may have broken apart this TV to see if they can sell you those parts.
I tried earlier but it did not move to the other side.
I noticed the small board on after the flat cable on the right is moved from its place.
Do you know what board is that ? How do we change it ?
It is the LCD panel signal distribution board.
It cannot be replaced as it is bonded to the LCD panel itself.
There is two of those board.
What else could it be ? This is driving me nuts not to found the root cause.
I will not give up until I found the root cause
Your screen has the same problem as shown in post5? Which is the same problem I had with mine. We are not getting clear answer from you, any pictures of the screen?
So I tried to change many cable such like
1. The one that goes rom tcon to communication board (where you have USB, hmdi,...)
2. Two Small cables that goes from tcon to a small board that goes to the screen,
3. Power board.
Now the screen turns on, show the line on the right and then turns black like if thee is no power and I get the sound. Like having a radio lol
Sounds like 2 seconds to black, can you see the backlight working in a dark room?
What do you mean by bad LCD panel ? Can it be fixed ?
I bad a look at the post but did not understood all of what the guy did.
If you can pinpoint the issue and how to solve it in a couple of line I would greatly apreciate.
I linked to the thread where budm fixed this issue.
