Lg 65UB950V No Image
  • nomoresonys
    • 12330
    • U.S.
    Re: Lg 65UB950V No Image
    there's some testing on a samsung, probably lots more on youtube: https://www.youtube.com/watch?v=rNqRZ2qaDJY
    • nomoresonys
      • 12330
      • U.S.
      Some testing there to look at, only throwing it up because of the testing info, not saying you should buy their tester, it's oos anyway: https://www.youtube.com/watch?v=4RzuLiRTzJg
      • nomoresonys
        • 12330
        • U.S.
        https://www.youtube.com/watch?v=EgRKJAqYqeo
        • nomoresonys
          • 12330
          • U.S.
          One for an lg there, pretty much giving the same info, pretty easy to follow: https://www.youtube.com/watch?v=6hQOiN4-XPk
          • Megaule
            • Aug 2023
            • 18
            • Italien
            So i demount the complete tv/panel... And the strange thing is that only 3 of 12 led "areas" go on when i make the stand alone test of the power supply. But the other led areas are good because i told the molsfet and give them ground with a bridge... And they work !! But the mosfets are not switching the gnd when i make the test... Only 3 of them... But voltage on gate it is!!!
            • Megaule
              • Aug 2023
              • 18
              • Italien
              #26
              This are the mosfet area on the pwrboard with the led driver, i told all the mosfets, only remains is in place, an one 1 connected with bridges... Thisone in place works... The other not...
              • Megaule
                • Aug 2023
                • 18
                • Italien
                #27
                • nomoresonys
                  • 12330
                  • U.S.
                  #28
                  Not sure what you are doing, if you have backlights out, they are likely bad, you can test them a few ways now that you have them uncovered, one of the easiest is rig up some 9 volt batteries and test the strips, many videos on youtube covering it. If you do test them with batteries be sure backlights are unplugged from the powerboard.
                  • Megaule
                    • Aug 2023
                    • 18
                    • Italien
                    #29
                    Hi, i had tested the backlights... They are good!!! But when i plug in the board, (pwron and drvon with 1k resistor on 3,5v) then the board will give me the 12v and 24v. Also the 80v for backlight i get, but only for 3 seconds, the the 80v go out. And only 3 of the mosfets switched the backlights on (3 of 12) all the other mosfet do not switch!! There must be a problem with the led driver ic!
                    • nomoresonys
                      • 12330
                      • U.S.
                      #30
                      Maybe test all the mosfets for shorts, make sure none of the 3 pins shows continuity to the other 2 pins of the mosfet.
                      • seb59
                        • Nov 2023
                        • France
                        #31
                        Hello.
                        I'm exactly the same problem wih my LG 65UB950V.
                        I have the 3,5v standyby, when i power on the tv i have also the 12v and 24v!
                        the 12v for tcon supply is missing
                        NO backlight (backlights turn on when i put 3.5V on DR-ON et P-DIMM 1 &2 but no image)
                        A led on power supply board flash 5 times
                        Etc…
                        I suppose that the problem is the mainboard…
                        • seb59
                          • Nov 2023
                          • France
                          #32
                          Hi
                          I tried the An-Klamm's method
                          I heat the yellow marked area and then I test it.
                          If that works, then you can let it cool down completely and try only one IC etc. Then you can narrow it down.
                          NOW, The backlights turn on, and i have 12V on the Tcon too, the led on power supply board didn't flash.
                          but NO IMAGE....
                          an idea?
                          • Secuman
                            • Jun 2025
                            Hello, has anyone found a final solution to the repair?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4537
                              • Italy - Milan
                              #34
                              Hi, a lot of confusion here, i suggest you to open your ownn thread, first need to test PSB alone with dummy loads, thern test PSB + backlights, then if ok possibly the main board also, LG are VERY very usual for BGA problems..
                                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:20 PM
                              • Jaime Morillo
                                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                by Jaime Morillo
                                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                The TV was stuck on the logo and I couldn't access the update menu.
                                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                The image result was good, but the image is inverted.
                                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                08-18-2025, 11:38 AM
                                HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                09-06-2024, 10:56 AM
                                HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
