Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
  • cheeky2
    • Dec 2012
    • 338
    I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
    Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
    The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
    Details:
    Toshiba 49U7763DB (UK model)
    Main: 17MB120 23438049
    Screen: VES490QNUS-2W-U01
    I can get hold of a same model TV main board for the Toshiba 55U7763DB which uses the VES550QNUS-2W-U01 screen which I am hoping is cross compatible with the VES490QNUS-2W-U01 screen? Can someone confirm this for me please?
    I can probably get the screen panel files from it though I will have to trawl through the forum to find the procedure as its been a while since I have played around with this ( I will have a look for the procedure).
    Any help would be appreciated Thanks
  • yokoono
    • Apr 2010
    • 510
    Re: Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic powe
    Try at your own risk. If there are problems with the remote control, use a Vestel or a programmable one.
    https://files.fm/u/brzmed8us
    The panel profile is saved with a folder called downloadpq.mb120 placed on the stick and typed from the remote control MENU/4725/USB Operations/OK.
    • cheeky2
      • Dec 2012
      • 338
      Thanks for that. I will save the panel files before I try it out.
      Thank you
      • cheeky2
        • Dec 2012
        • 338
        Thanks for replying to me in the other Turkish forum and on this one as well and providing the software it is appreciated. Unfortunately it hasn't resolved the issues, however I have the panel files and will purchase the 55inch version of this board and put the panel files on it.
        Does the SPI flash ic on the 17MB120 board contain the details of the remote control codes as the TV is constantly thinking the left hand remote control button is being pressed. It's not the power button/joystick as the unit has been disconnected from the TV. As if it is then I can read the working flash from the other 55inch main board TV and try it in my original board and hopefully get both working
        Regards Anthony
        • anlu
          Vestel Firmware - Toshiba 32W133DN
          by anlu
          Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
          Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
          02-04-2023, 12:59 AM
        • Bazilwrc164
          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
          by Bazilwrc164
          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
          If anyone can provide:
          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
          • Or a compatible EEPROM dump
          07-23-2025, 12:15 PM
        • DarrenHD
          Firmware for older Toshiba TV 22CV100U
          by DarrenHD
          HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
          I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
          https://support.dynabook.com/support...tentId=2865076
          Thanks!
          06-16-2025, 11:56 AM
        • RAZ777
          Toshiba 40L3653DB Vestel firmware
          by RAZ777
          Hi Guys,
          I have a Toshiba 40L3653DB with flashing green/red led - firmware fault.
          It has the vestel 17MB110 board.
          Anyone know where I could get firmware?
          02-16-2022, 07:56 AM
          09-06-2024, 05:27 AM
