Samsung qe55q60rat
    Samsung qe55q60rat
    I have a motherboard that failed after a wrong software update. I couldn't find the software for this motherboard and bought a new motherboard. But the panel didn't fit my new motherboard either. I am getting a distorted image. Does anyone have full eprom and emmc software suitable for this motherboard and model?
    television model; QE55Q60RAT
    motherboard model; BN41-02695A
    panel mode; CY-RR055FGLV1H
    IC1502-IC1503-IC801- IC701 EMMC
    Re: Samsung qe55q60rat
    Never search a mainboard via the BN41-xxxxxX code, there is a label with the correct code that starts with BN94-xxxxxX.
      old motherboard;bn94-14581a
      new motherboard;bn94-14784m
        Bn94-14784m - qe82q60r
          The bn94-14784m coded card screen was removed from the broken qe55q60rattan, but my device is the same model, the panel is different, I guess so it probably didn't fit.. Do you have compatible eprom and emmc software?
            eMMC you don't need, try throwing SPI Flash 25Q80 (t-con), it contains the contents of your panel (if, always make backup copies of these flash!).
            If the image appears, then change it to your panel number in the service menu.
              Thank you for your help. do you have a solid spi flash file you can share?
              I transferred the spi flash of my card with corrupt emmc software to this card, but I could not get a result.
                I did some resistor changes on the motherboard and finally got an image. But vertical lines appeared on the panel, and the software still did not fit. I cannot find fully compatible software. I inserted the eprom of the old card I removed and it looks a bit hazy. Any chance of adapting the data of the old card to the data of the new card? I have backed up 2 files, does anyone know about this? I would appreciate it if you could help me edit the file.
                  Try
                    Try
                    I tried both software but no image. There are white and blue colors, that's all.
                      Based solely on the "BN41" reference you won't find the software you need, use the "BN94" reference, moreover there might be slight changes on PCB like resistors for example even though it is the same "BN41" reference. Then if the problem persists, it means that the firmware in eMMC is not the same for both ( which I would doubt ) so you would have to transfer eMMc from one PCB to the other, with the two eeproms if their contents are different from a mainboard to the other.
                      I am not sure whether you can change panel reference from the code in the eeprom but I doubt it ( if you can please tell me how you did it, I am eager to know it !). But transferring the emmc would be the best option, please send images of both motherboards on the forum.
                        Try
                        Dear Lotas. May I know what display memory this is? i need auo
