hyundai led tv 39hyn3908 strange problem
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi
    on the above tv
    when i look on source tv all ok
    when i connect an external device via hdmi
    after few minutes the image become dark without backlight and i can see
    the image with the help of a torc
    my question is why i have not the same issue when i wach and i have choose the source tv ?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Re: hyundai led tv 39hyn3908 strange problem
    turn the back lights down to 50 or 60% and the back light should stay on longer. One or more of the leds is / are failing.
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      thanks a lot sir for the help
      something more
      does anybody know what type of led strip has the above model ?
      because i found only for 39hyn3901
      • Xristakis795
        • Mar 2021
        • 162
        • Greece
        The panel of tv writes
        ves390wnda-2d-n12
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
        • vabea
          Asus X550LD Image problem
          by vabea
          Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
          Thanks...
          04-07-2025, 08:33 AM
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
          09-06-2024, 10:56 AM
