What SMD component is this?
  • zezone
    • Jun 2022
    • 4
    • Italy
    Guys , does anyone know what this SMD component is? It looks like a diode, but it has the white line in the middle instead of at the edges.
    I checked it with multimeter, and it was open.
  • lotas
    • Jan 2016
    • 4850
    • Russia
    Re: What SMD component is this?
    TVS diode, if in doubt, you can remove it.
    • zezone
      • Jun 2022
      • 4
      • Italy
      Thanks!
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
      • darkness77
        Multimeter diode mode question
        by darkness77
        Hi, i am noob in repairing electronics and motherboards...and most of the time i am still trying to understand how things work...So, lately i have been using and testing motherboards in diode mode. Most of the motherboards that i test are not working and broken. The question is that if i use multimeter in diode mode on high 19vol rails sometimes i read fixed number in multimeter but on some other boards reading in diode mode is rising indefinitely till i read 1. I am talking on lets say ac_bat 19volt rails on motherboards. So, i dont understand how it is rising indefinitely? In theory if only...
        06-14-2021, 02:29 PM
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
      • yayayee
        ASUS GU502GV not powering on - 1285A hot
        by yayayee
        I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
        So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
        I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
        01-08-2024, 11:04 PM
