Samsung TV UN60J6200AF No Display + No LED
  • Bigfoot
    • Mar 2023
    • 12
    • Usa
    Hi guys
    I'm working on similar Samsung TV UN60J6200AF.
    When I plug in power cord, the red light lights up, and flashes, then turns off.
    I measured on the power supply board, and even without pressing the power on zbutton in getting on CNM803 (which goes from Power supply to Main board):
    UD = 2.3V
    PMW_BLU4 = 3.3V
    PS_ON = 4.4V
    A13V = 12.75V
    I looked at the manual and all the voltages are correct.
    When I unplug the main board from the power supply, LED lights are supposed to come on. However, non do come on.
    Power supply board p/n is: bn44-00775a
    I then measured at the LED connector CNL802:
    D+ to D - = 419 VDC
    All the other connections on the LED plug to ground show 0 VDC on the connector.
    I wanted to verify LEDs are good or not, so using SID LED tester MODEL: KT4H, I injected 210V between D- and S+ and the full backboard LEDs lit up. The voltage on meter dropped to around 113V. Then I injected voltage on D+ and S-, and the full backboard LEDs lit up. The voltage on meter dropped to around 113V same as the other loop. And all the LEDs seemed to be lit.
    Lastly I tried to put the TV in LED force mode by unplugging the main board from the power supply, the LED lights are supposed to come on. However, non do come on.
    I was able to measure, when TV is plugged in, and motherboard cable is disconnected:
    PMW_BLU4 = 3.3V
    When the motherboard is connected I get:
    UD = 0.065V
    PMW_BLU4 = 0.1V
    PS_ON = 3.3V
    A13V = 12.75V
    Finally..
    When I check voltage to the LEDs with out connector connected it is showing 419VDC+ volts first pin (D+, picture attached) to ground and 0VDC to the rest of the connections to ground. The same happens when I plug in the LED connector and also when I unplug it.
    Any help would be greatly appreciated.
  • lotas
    • Jan 2016
    • 4880
    • Russia
    Re: Samsung TV UN60J6200AF No Display + No LED
    You need to measure the voltage at +D relative to -D, not GND. You should have under load (with connected LEDs) 325V.
    • Bigfoot
      • Mar 2023
      • 12
      • Usa
      Thanks for your reply.
      I have 419V between D- and D+, when the LEDs are connected.
      The voltage is high, is there anyway to check if the IC driver is the problem?
      • Bigfoot
        • Mar 2023
        • 12
        • Usa
        I found the IC on eBay, but I can't find any data sheet on it
        • lotas
          • Jan 2016
          • 4880
          • Russia
          Check the transistor and diode for a short circuit.
          • lotas
            • Jan 2016
            • 4880
            • Russia
            There is no datasheet for this chip (Samsung engineers like to keep their information secret,
            however, there is information that the MAP3511 is an approximate analogue of this microcircuit.
            • Bigfoot
              • Mar 2023
              • 12
              • Usa
              Thank you for your suggestion.
              I had already checked the transistor and diode, neither is shorted both seem good.
              • Bigfoot
                • Mar 2023
                • 12
                • Usa
                Thank you for the help.
                I'll try to check for any obvious anomalies on my IC.
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
