Dead Samsung ue55mu6120kxzt
  • mennyx
    • Apr 2023
    • 12
    • italy
    Hi there,
    i have a problem with the tv in the description. The stand-by led is always off. I controlled the power board and it is ok. A friend of mine told me to try flashing the motherboard bios with a ch341a programmer, but i've some questions.
    I have read some guides and i assembled the usb programmer like this (i think it is correct):
    https://ibb.co/7NcMD5P
    https://ibb.co/KzBwBwn
    Bios chipset:
    https://ibb.co/6Z6LgQZ
    I installed the drivers and the ch341a appears on the devices and i downloaded some vers of programmer software, but when i connect the "pincers" to the bios in the programmer software the "detect" button turn gray and it's no more clickable. The red cable of the pincers is on the chip connector with the "little hole" so it shouldd be correct.
    I'm doing something wrong, but i don't know what.
    More photos of the tv mainboard and lcd pannel:
    https://ibb.co/RTN64Jm
    https://ibb.co/TP1YwP2
    https://ibb.co/3WCpTXb
    Thx for the help
  • lotas
    • Jan 2016
    • 4860
    • Russia
    Re: Dead Samsung ue55mu6120kxzt
    Never use this "clothespin", carefully unsolder this flash (without damaging nearby components) and read its contents (dump) and post it here.
    • mennyx
      • Apr 2023
      • 12
      • italy
      thx! i'll try. By the way, the connection of the ch341a componets are correct?
      Thx
      • lotas
        • Jan 2016
        • 4860
        • Russia
        I didn't understand your question, I wrote about the components near the flash (resistors, capacitors), when you solder, so as not to damage them.
        • mennyx
          • Apr 2023
          • 12
          • italy
          sorry, i meant the ch341a connections. This ones:
          https://ibb.co/b15rjtG
          https://ibb.co/zxV5nkQ
          https://ibb.co/4TGFQK0
          • lotas
            • Jan 2016
            • 4860
            • Russia
            Not right! You have 1 red wire should be on the other side.
            • mennyx
              • Apr 2023
              • 12
              • italy
              Ok, so i use ch-341 programmer v 1.43 (chip w25q40cl). The detect function works fine, but i have this result:
              https://ibb.co/JtpGZkT
              Zipped file attached.
              • lotas
                • Jan 2016
                • 4860
                • Russia
                Yes, your dump is not working, try the corrected one, do not forget to set and write the status register (0x88, 0x42) after writing the dump.
                • mennyx
                  • Apr 2023
                  • 12
                  • italy
                  Ok i wrote the new version. But i don't know what i've to do with the status register you were talking about. How to set and write it?
                  Thx
                  • mennyx
                    • Apr 2023
                    • 12
                    • italy
                    ok, i found an old post made by you:
                    https://www.badcaps.net/forum/showpo...9&postcount=74
                    and i saw you used 2 more programs to set and write the status register. I have to use that or i can set and write via ch341 programmer?
                    thx a lot
                    • lotas
                      • Jan 2016
                      • 4860
                      • Russia
                      After writing the dump, click on "Chip" and at the very bottom select "Status Register" and check the boxes to receive (0x88, 0x42, 0x00) and click write. And that's it. ready.
                      • mennyx
                        • Apr 2023
                        • 12
                        • italy
                        this is what i see, but i don't understand the boxes to check. Is it correct? Or i have to click on write without any modifications?
                        thx
                        • lotas
                          • Jan 2016
                          • 4860
                          • Russia
                          That's how it should be.
                          • mennyx
                            • Apr 2023
                            • 12
                            • italy
                            ok, done. I try to put it back in the tv and i see!
                            Thx for the helps! You made my day!
                            • lotas
                              • Jan 2016
                              • 4860
                              • Russia
                              Please. The day was not wasted.
                              • mennyx
                                • Apr 2023
                                • 12
                                • italy
                                IT WORKS! Lotas thx a lot for the patience and the accurate tips you gave to me!
                                Thanks, thanks, thanks!
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4539
                                  • Italy - Milan
                                  you finally read / written using the clip?
                                  • mennyx
                                    • Apr 2023
                                    • 12
                                    • italy
                                    yeah i use the clip without desoldering anything
                                    • mennyx
                                      • Apr 2023
                                      • 12
                                      • italy
                                      the initial problem was the wrong connection between the clip and the usb programmer
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4539
                                        • Italy - Milan
                                        ok thanks
                                        • what_1282105
                                          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                          by what_1282105
                                          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                          02-14-2025, 07:27 PM
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
