tv samsung UE55K5500AK no start
  • madjid911
    • Dec 2016
    • 390
    • France
    Hi, I have a samsung tv that does not start at all, the red light is on, it flashes when I press the remote control, but the TV does not start
    TV samsung model : UE55K5500AK
    POWER SUPPLY : BN44-00872C L55E1_KSM REV 1.1
    Motherboard : BN41-02534
    T-CON : TT4851B01-1-C-3
    Here are my tests :
    -When I unplug the tablecloth from the motherboard, the LEDs light up
    -I have 12v fine on the T-CON board, no shorts, fusible is good, no change when i unplug the t-con board.
    -I did not find a dead or shorted component on the motherboard, the processor heats up normally.
    My measurements on the power board:
    Power supply without the motherboard
    11 0v 12 0v GND
    9 12V8 10 0v GND
    7 12V8 8 4V5 PS-on
    5 12V8 6 3V3 BLU_PWN
    3 12V8 4 4V51 OD/UD
    1 0v 2 3V59 OD_ON/OFF
    Power supply with the motherboard
    11 0v 12 0v GND
    9 12V8 10 0v GND
    7 12V8 8 3V3 PS-on
    5 12V8 6 0V BLU_PWN
    3 12V8 4 3V45 OD/UD
    1 0v 2 3V58 OD_ON/OFF
    Do you have an idea please?
    • 12200
    • U.S.
    Re: tv samsung UE55K5500AK no start
    Can you write that out again, having a hard time deciphering that style.
    • madjid911
      • Dec 2016
      • 390
      • France
      12 0v GND
      11 0v
      10 0v GND
      9 12V8 10 0v GND
      8 4V5 PS-on
      7 12V8
      6 3V3 BLU_PWN
      4 4V51 OD/UD
      3 12V8
      2 3V59 OD_ON/OFF
      1 0v
      12 0v GND
      11 0v
      10 0v GND
      9 12V8
      8 3V3 PS-on
      7 12V8
      6 0V BLU_PWN
      5 12V8
      4 3V45 OD/UD
      3 12V8
      2 3V58 OD_ON/OFF
      1 0v
      I don't understand why I don't have one even with the motherboard unplugged, is it the wrong pin?
        • 12200
        • U.S.
        CN9101 -____________OFF______ON
        PIN 1 - +5V/+3.5V__5.12V_____5.14
        PIN 3 - +12V -______19.17V___19.13
        PIN 5 - +12V -______19.17V___19.14
        PIN 7 - +12V_A _____19.17V___19.16
        PIN 9 - GND -________0V______0
        PIN 11 - GND ________0V______0
        PIN 13 - 3D _________0V______0
        PIN 15 - ON/OFF _____0.1V____3.22
        CN9102 -
        PIN 2 - +5V/+3.5V -__5.12V___5.14
        PIN 4 - +12V - ______19.17V__19.16
        PIN 6 - +12V - ______19.17V__19.14
        PIN 8 - +12V_A -_____19.17V__19.16
        PIN 10 - GND -_______0V______0V
        PIN 12 - GND - ______0V______0V
        PIN 14 - PS_ON -_____0.5V____3.68
        PIN 16 - DIM -_______0V______3.27 Report it like that so it makes more sense.
          • 12200
          • U.S.
          So pin #, expected voltage, actual voltage when off, actual voltage when you power on, no need to report the grounds.
          • madjid911
            • Dec 2016
            • 390
            • France
            ok thanks, sorry i am new to tv troubleshooting
            I checked everything I did not find a dead or shorted component, it may be due to the backlighting, before you a solution to test the led bars without dismantling everything?
              • 12200
              • U.S.
              RJ touches on testing backlights in post 34 of this thread: https://www.badcaps.net/forum/showthread.php?t=116512
              • madjid911
                • Dec 2016
                • 390
                • France
                that didn't help me sorry,
                1 NC =0
                2 OD_ON/OFF =3.58V
                3 A13V =12.8V
                4 OD/UD =3.45V
                5 A13V =12.8V
                6 Blu_Pwm =0V
                7 A13V =12.8V
                8 Ps_ON /OFF = 3,3V
                9 A13V =12.8V
                10 GND
                11 GND
                12 GND
                to be sure it's not the leds, I'd like to connect the stanby with the ps-on, but I'd like to know what signal is on the leds? Is it Blu_Pwm ? here I have 0v on Blu_Pwm, if it is the signal that triggers my leds then if I connect Blu_Pwm to ps-on, the leds should light up, right? I don't want to do anything stupid, I'm still a young beginner
                  • 12200
                  • U.S.
                  Ok, now we can tell what the pins are, now unhook cable from powerboard to mainboard on powerboard side, plug power cord in, test each pin, just tell which pins have voltage and the amount like 3.3 etc, be careful to only touch one pin at a time with the probe.
                  • madjid911
                    • Dec 2016
                    • 390
                    • France
                    here are the measurements without the motherboard. the backlight turns on.
                    1 NC =0
                    2 OD_ON/OFF =3.58V
                    3 A13V =12.8V
                    4 OD/UD =4.51V
                    5 A13V =12.8V
                    6 Blu_Pwm =3.3V
                    7 A13V =12.8V
                    8 Ps_ON /OFF = 4.5V
                    9 A13V =12.8V
                    10 GND
                    11 GND
                    12 GND
                    do you have an idea ? THANKS
                      • 12200
                      • U.S.
                      Ok when you do that and the backlights come on and stay on, that usually means the backlights and powerboard are ok, try turning on tv with one cable unhooked from tcon to panel driver board, see if there's anything on display then do the other side same way, best policy is make all connections and dis-connections with tv unplugged from power to avoid any errant surges and such.
                      • madjid911
                        • Dec 2016
                        • 390
                        • France
                        yes that's the first thing I did, I connected and disconnected each tablecloth each but no change.
                        It's probably the motherboard that died, but I would have liked to know how to connect the ps-on to the stanby and also the backlight signal to be sure that the power supply board is good
                          • 12200
                          • U.S.
                          Well looks like you have an always on powerboard and the voltages look good, so yep looks like a mainboard issue.
                            • 12200
                            • U.S.
                            6 Blu_Pwm =3.3V seems to be the problem, when mainboard is connected it looks like the mainboard is keeping it low for some reason, maybe trace that line back thru the mainboard and see where it goes.
                            • madjid911
                              • Dec 2016
                              • 390
                              • France
                              I followed in continuity blu_pwn on the motherboard, and I arrive at this component (k72), see photo, I can't find any shorts, Could the component be dead? I can't find it on the internet
                              • lotas
                                • Jan 2016
                                • 4610
                                • Russia
                                K72 - 2n7002
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  Blu_Pwm its belong to BL. its normal to be high when MB disconnected so BL turn on.
                                  you have firmware issue didn't start... check after it SPI and lotas the one who can check the dump content of it. in case there are spi
                                  • madjid911
                                    • Dec 2016
                                    • 390
                                    • France
                                    Originally posted by lotas
                                    K72 - 2n7002
                                    thank you , can i shunt the drain and gate to get my 3.3V?
                                    • madjid911
                                      • Dec 2016
                                      • 390
                                      • France
                                      I had tried to find the firmware to flash the motherboard, but I did not find
                                      • lotas
                                        • Jan 2016
                                        • 4610
                                        • Russia
                                        Dump spi (24Q40) I have for testing, but rather a problem with the eMMC firmware.
                                          09-07-2024, 05:50 AM
                                        • moltensolderlabs
                                          Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
                                          by moltensolderlabs
                                          Hi everyone. [Sorry for the long, detailed post in advance].
                                          I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
                                          10-09-2020, 12:01 PM
                                        • roman_v61
                                          Samsung Book2 pro np950xed-kf1US motherboard stock issue
                                          by roman_v61
                                          this is my kinda final resort.
                                          My sister was very happy with her samsung laptop,
                                          she used it for 2 years.
                                          suddenly the laptop failed to start and after exmining it in the lab,
                                          it appers the motherboard is dead and I need to get a new one.
                                          the problem is that there is no motherboard to be found nowhere on the web.
                                          can somebody advice what can I do?
                                          except for buying a new laptop.
                                          laptop model:
                                          samsung book2 pro np950xed-kf1US
                                          thank you in advance,
                                          Roman
                                          07-14-2024, 09:27 AM
                                          09-06-2024, 11:40 PM
