Hisense 50P6
    Re: Hisense 50P6
    Originally posted by viewerau View Post
    When I right click the file,(my link) it will only allow these options
    Preview
    Download
    Copy to
    Details
    If I select Copy to...I can't seem to save it
    If I download it, it turns into this zip folder
    If I extract then, it just comes back with all those folders again.
    My apology for not understanding how to simply grab that one file
    HELP....
    Rename it (extension .rar to .pkg) to get the file : usb_AA6501U.pkg
      Re: Hisense 50P6
      Originally posted by nomoresonys View Post
      How bout, left click hold, drag and drop, send to should also work.
      No go either...can any of you access the file via the link I sent, or doesn't the link work for you guys?
      Signature:Seemingly hopeless tv fixer
        Re: Hisense 50P6
        It's just that your computer perceives files with the pkg extension as rar (you installed, checked the box so that these files can only be opened by the rar archiver).
        If you need to quickly do this, then try on another computer.
          Re: Hisense 50P6
          Try Lotus solution, if still stuck maybe this, scroll down to manual update section: https://knowtechie.com/how-to-update...e-tv-software/
            Re: Hisense 50P6
            manual update.......cannot do that nomoresonys as the tv is stuck with the lines on it, and I cannot see the menus.
            I have uninstalled all my rar, onezip, etc apps...still won't let me move the file anywhere
              Re: Hisense 50P6
              Another tutorial there, he talks a lot but does go into detail, might help: https://www.youtube.com/watch?v=KjGDubuxhaY
                Re: Hisense 50P6
                I think you are looking at the auto update part, the manual part is way down the list there but doesn't go into great detail.
                  Re: Hisense 50P6
                  I uninstalled all my apps that do zips, rars etc, and then downloaded it, and it saved as the file.
                  Hopefully this looks right?
                    Re: Hisense 50P6
                    Ok, so is that the first file after you extract? then you should be able to move that file to your usb drive, right?
                      Re: Hisense 50P6
                      It is the third file from the Hisense link.
                      Putting onto usb now
                        Re: Hisense 50P6
                        Yes, you need to transfer this file to a formatted usb stick.
                          Re: Hisense 50P6
                          Back to square one again.
                          The usb simply seems to be doing nothing.
                          I keep power unplugged, and drain the power by either holding down the tv or remote power button for 60 seconds.
                          I then keep holding the power button and plug in the power, holding, awaiting device notification or boot, but that never arrives.
                          I did also change the file name to upgrade_loader.pkg....no difference.
                          Tried either usb port...ditto
                          My luck with repairs is abysmal.
                          Are we at the end of any help now?
                          Thanks all.
                            Re: Hisense 50P6
                            my post#52 read it again.. your problem at PC
                            1- you need to active at Folder Option to show known extension file .. so you can see the last extension to avoid it written .pkg.pkg
                            2- rename the file to upgrade_loader.pkg
                              Re: Hisense 50P6
                              BTW: yours link of firmware in post#55 its belong only to yours e.mail to download... no other third party can download it.
                                Re: Hisense 50P6
                                Originally posted by Diah View Post
                                1- usb formatted as FAT32 MBR mode
                                2- the first file with format .pkg dont extract it. just copy it on the stick
                                3- you may need to rename the file upgrade_loader.pkg in case didnt start
                                4- no need 60 second. as son you press power on RC and keep press plug the tv in wall
                                5-insert the USB at USB Ver2 ( black socket at the side of the TV
                                Thanks Diah,
                                I am certain that this is what I have done.
                                I did not realise that you could not see the file, but it is as before, posted here again, and is file number 3
                                I did it all again
                                No change
                                I d/l it and it shows as usb_AA6501U.pkg
                                I transfer the file onto formatted FAT 32 stick
                                I plugged it to tv and it would not boot.
                                I removed usb, changed file name to
                                upgrade_loader.pkg
                                Reinsert to tv
                                All no go still
                                I do not know what/how to format is as FAT32 MBR mode
                                I look in google via search, and it says ....
                                "The first is to simply format the drive using the MBR format. This can be done in Windows by right-clicking on the drive in My Computer and selecting Format. In the Format dialog box, select the option to format the drive for MBR."
                                When I do this I only have the options
                                NTFS
                                FAT32 (default)
                                exFAT
                                In disk management it shows my usb as D 14.32GB FAT32 Healthy Primary Partition
                                It shows no errors.
                                Am I doing this right?
                                THANK YOU
                                EDIT...file ext only shows .pkg the once.
                                  Re: Hisense 50P6
                                  Thanks Diah,
                                  if you have srick smaller than 32Gb will be fine.. however to make MBR mode
                                  open CMD on yours PC
                                  write
                                  Code:
                                  1- diskpart  press inter disk part will start
                                  2- list disk  it will show you all disk on PC be sure to choice yours usb stick for example if it under disk 1
                                  3- select disk 1
                                  4- clean
                                  5- convert mbr
                                  6- create partition primary
                                  7- active
                                  8- list partition
                                  9- select partition 1
                                  10- format fs=fat32 quick
                                  11- assign
                                  12- exit
                                  13- exit
                                    Re: Hisense 50P6
                                    Maybe that usb drive doesn't want to play nice with your tv, try a different one, you have any less than 8gb?
                                      Re: Hisense 50P6
                                      Thanks again for the suggestions...I will dig out a small GB USB stick and try again
                                        Re: Hisense 50P6
                                        lotas, Diah,nomoresonys...
                                        I followed Diah instructions exactly, thanks for the very clear instructions.
                                        I used a 4GB usb stick this time.
                                        Loaded it with the file, changed it's name to upgrade_loader.pkg
                                        Inserted it to Hisense usb port, press power on remote, await boot to let go of power button
                                        Unfortunately it still does as it did before, going straight into the coloured vertical lines, with nothing thereafter.
                                        Tried a number of times, as well as trying in both of the Hisense usb ports.
                                        Gosh, it seems so simple a thing to do, but this Hisense is simply not behaving for us.
                                        Anything else we can try do you think?
                                        Thank you everyone.
                                          Re: Hisense 50P6
                                          Thank you everyone.
                                          my post #21
                                          replace MB
