Originally posted by zaratustrax
View Post
Samsung UN55MU6103F IC1604 dump
First at all Thanks for taking the time and check my file.
As you said the problem is some where else. I was looking for and I discovered that the problem is on the panel side.
I made a trick, I dissabled the Tcon protection which detetcs if the panel is connected to the Main board. So I could discovered where the problem was. And it is on the left side.
This tv has two boards in which are Soldered the cofs. So we have a 'board-cof' left and right. And also each one is divided in two board connected through a Coffee color flex.
I cheked this part and I couldnt find any Short or low resistente, I also try to dissabled the board in which the problem is cutting the ckv lines and covering with tape the voltages lines.
At this point I am stuck. I am wondering if the problem are the cofs or this side of the panel is broken or something.
Could you please tell me another way to 'turn off' or dissable this part of the panel in which the problem is?
Again, Thanks a lot for your help
Originally posted by srdi View PostThe TV does not turn on, there is no standby mode! SAMSUNG UE40MU6402Attached Files
Originally posted by edukojak View PostHello friends. I'm new here and I noticed that everyone helps each other. I'm from Brazil and I'm looking for the bios for the Samsung 50 MU6100G BN41 02568A BN49 12418K TV. Does anyone have this?
Originally posted by murtagh View PostHi Lotas ,can you fix this file please. I have used some of your files before and they worked ,thank you. Samsung UE49MU6500 BN41-02568 ic1604.
Murtagh,
Ireland.Attached Files
