Samsung UN60D8000YF Clicking BN44-0432A
  • mikelu53
    • Jan 2023
    • 11
    I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
    The set was working then not,then started clicking.
    Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
    Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
    A schematic or suggestion would be great.
  • R_J
    • 9607
    Re: Samsung UN60D8000YF Clicking BN44-0432A
    Do you have a constant A5V +5 volt standby? Use HS804 (heat sink) and check the voltage on BBS851 or BB852 (both are in parallel)]
    I would replace CS802 and CS805
    • mikelu53
      • Jan 2023
      • 11
      The 5 volts is not constant while the relay is clicking, changed the caps, still a problem.
      Tried to ground and +4.5 the power on pin 28, with no effect. When the click stopped I could turn the PS on/off with pin 28, back lights would then come on as I am guessing they should.
      I am guessing the clicking is some kind of startup sequence that is failing, and it keeps restarting.
      Second I am guessing you can start the PS without the main board attached.
      • R_J
        • 9607
        Check that there are no shorted diode in the secondary of the main transformer, check that the solder connections are ok on tm801s
        Check that NT813S (thermistor) is not bad or open.
        Also make sure you disconnect the led's from the power supply in case they are causing the problem.
        • mikelu53
          • Jan 2023
          • 11
          Have checked all diodes (using diode test on meter), re flowed solder on all transformers, NT813S reads 33ohms in the circuit. LED are not connected. When it dose stop clicking 5v on DS853, 18v on DM853, 12v on DM854,855, 88v on dm852
          thanks
          • R_J
            • 9607
            The relay is clicking because it is either loosing its supply voltage or the transistor that turns it on is being turned off.. You could try and eliminate CS855 and CS857 as not the issue by bridging them with another 100µf/ Connect it between hs804 and BBS852.
            Can you place the power supply in standby by grounding the Power On/Off pin.
            • mikelu53
              • Jan 2023
              • 11
              With the PS commanded to off, all is stable +5 is good, as soon as commanded to turn on by removing the ground, all is bad +5 jumps as before.
              When power is removed the clicking continues for at least 10sec or more.
              Also tried to short the relay contacts, no change
              • R_J
                • 9607
                So everything is stable in standby, but when the main pwm ic and pfc circuit start the power supply is unstable, Can you check the VCC voltage across CP805 and see the value and if it is stable?
                • mikelu53
                  • Jan 2023
                  • 11
                  The voltage is a solid +15
                  FYI
                  I Lifted fuse FP8035, and the on/off turns the relay on a off (no clicking), so what ever I disconnected seems to be the problem, the +5 is stable. I probably disconnected the whole cold side.
                  • R_J
                    • 9607
                    That vcc voltage is likely ok
                    FP803S is in the supply voltage line for the main switching mosfets for the main transformer. I wonder if it could be CS818 at fault Unlikely but you never know? There are also a number of diodes in the line, DS810, DS811 etc. I wonder if one of them might be bad?
                    Or it could be that CM809 or CM806 are weak, they are likely for the main pwm controller vcc. If one of them is weak the the ic will start, fail and restart. If it is a SEM3110, I believe the ic's turn off on the vcc is about 9v and turn ON about 10.5v
                    • mikelu53
                      • Jan 2023
                      • 11
                      I appreciate your help, but would you be willing to share the schematic I assume your are looking at? I would not redistribute it, just for my use.
                      I have lifted many caps and diodes, a few legs of mosfets, but no smoking gun
                      Again thanks
                      • R_J
                        • 9607
                        This is what I am using, there are no schematics for this model
                        • mikelu53
                          • Jan 2023
                          • 11
                          Wow, I would have bet big saying you had a schematic.
                          The only time I go it to stop clicking is when I probed the iso isolator 8035 near the center of the board.
                          Was going to try a short the output to fake a good signal, to see what happens
                          I am thinking the feedback voltage is flaky, have found other schematic that kind of have the same parts 0BN44-00357B
                          I am testing caps with a cap function of the volt meter, don't have a ESR meter
                          • R_J
                            • 9607
                            What do you mean by
                            Probed with what, meter? and which pins did you probe and where was your meter ground? (hot ground or cold ground)
                            You can't check caps with a meter very accurately, The best way would be to use a scope or just replace them.
                            • mikelu53
                              • Jan 2023
                              • 11
                              The meter only check cap not the internal resistance, I had a esr meter but, it died, it was $5
                              Anyway I put a 10uf cap from the cathode (led side) of the isolator 8035 to cold side ground, every thing worked even the TV itself, how ever after about 5 min it didn't.
                              So atleast I know the rest of the set is ok.
                              I opto is controlled by the 12volt output thru a bunch of resistor and smd caps.
                              going to recheck the 12voltage output caps, tried to parallel a bigger cap but no luck
                              Have a new ESR meter on the way
                              • mikelu53
                                • Jan 2023
                                • 11
                                Still at it, found a schematic that is close bn44-00428b.pdf, I opened fuse fp80835 which supply's the PFC to the main output, clicking stopped. With the fuse inplace the PFC voltage jumps around. I tried to measure the PFC current to the main output, which seems to go up to the 12A range, I guess it shuts down fast enough to not blow the fuse.
                                Have checked components around the controlling IC "UCC25600 8-Pin High-Performance Resonant Mode Controller". Shorting out the opto for this chip shuts it down and stops the jumping.
                                Have not found any bad components yet, don't know why the current is so high that it pulls down the PFC.
                                  09-07-2024, 05:50 AM
                                • Asraf Atb
                                  by Asraf Atb
                                  01-27-2025, 05:02 PM
                                • JSin21
                                  Compatibility of main boards between different variations of samsung MU6100
                                  by JSin21
                                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                  11-27-2023, 04:54 AM
                                • mrautom8
                                  Samsung TV UN75H6350AFXZC main board schematics?
                                  by mrautom8
                                  Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                  Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                  While relay is on, all voltage rails are present and steady (scoped) on main board.
                                  I love a good logic puzzle but getting lost without any schematics.
                                  No shorts on ANY capacitor main board.
                                  Thermal camera shows 3.3V inductor getting warm instantly but...
                                  10-19-2025, 06:32 PM
                                • bffargo
                                  2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                  by bffargo
                                  LG 60PB66550 NOV 2014
                                  PSU: EAY63168603
                                  PCB: EAX65359531 2013.11.01 Rev:1.0
                                  Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                  Symptom:
                                  While watching, just went black and started clicking relay every few seconds.
                                  Initial diagnosis:
                                  Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                  Deeper diagnosis:
                                  Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                  09-09-2022, 07:34 PM
